Roll/wind A Mainspring By Hand?
Hi mark, I came across some watch repair page where one follow the book/traditional way which is winding back a mainspring by hand without using any mainspring winder. I would like to ask you if that's possible? If so, could you make a video on how to? Specifically for the miyota 8200 or dg2813 or maybe any automatic movement just to let me have a rough idea. Reasons for miyota and dg is because I work on those movement more and partly because eta we can buy the whole barrel. Thank you very much. As I have been trying to put back the mainspring by hand but ended up scratching the barrel wall and broke the mainspring. Because as you know this watchmaking hobby is very costly. I'm doing it for a hobby so I couldn't afford owning every single tool. I bought one mainspring winder but I think I bought the wrong one so it ended up lying at a corner collecting dust. Thank you very much. I seriously appreciate it.
It is possible to wind a manul wind main spring, but automatic watch main spring is another thing.
I have mainspring winders, but there are times that I hand wind a main spring in old American Pocket watch movements.
I would pratice on a large main spring like a old american pocket watch before you try a smaller one like a mens manual wind
watch.
I have done a number in the manner you suggest. Autos and manuals. You start with the end that hooks in the barrel. The initial placement matters in some barrels such as a T end in a pocket watch. Automatics and hole ends that will catch on winding dont matter quite as much. The operation is backwards of unwinding it a half turn at a time by pinching with the fingernails. I believe that was shown in a video somewhere. The trickiest part is getting the first full revolution from the outside wound and pinched in your fingers. After that its not to difficult to wind and pinch a half turn at a time.
remember outside first,arbor end last
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
