ETA 955.412
Does it quick set ok or does it feel stiff. Is your date wheel locking spring bent too far causing too much friction with the date wheel.
If you've put it all back together exactly as Marks video I cant see why its not working.
Looks like its time to strip down the dial side date workings and check your work I think. And when you do leave the dial off and movement out of the case so you can study the dial ring as it auto changes you might spot the problem. If it changes ok its something to do with the dial have you put the dial washer back in place.
  • 4 years later...
Sorry for waking up an old thread. I experienced the same thing with my Tag Heuer wk1211, which uses this movement. Google brought me to this discussion.
Originally, when changing battery, the store suggest me to replace the movement with a new one because he spotted signs of battery leakage. So I agree with him. However, after the change, the date wheel sometimes stuck on certain dates. I took it back to service, but it seemed they cannot fix it.
I wonder if the OP or anyone else have solved the problem?
Either give the watch to a reputable repairer that works on quartz (there aren't many, you can try Archer Watches), or replace it, easier said than done since it's discontinued.
There is no clear better cost and inconvenience choice between these two, so good luck.
Sending the watch across the globe to Archer Watches is sadly almost impossible for me (I lived in South East Asia) :lol:
I think I made up my mind to leave the watch as it is, and start saving for a new watch instead.... probably an Omega.
thanks for your reply, man
You didn't mention you country but for the record I've shipped in and out registered post without any problem from various ones in SE.
If your concern is about customs duties then the best approach is to declare a low value both ways, and save the outgoing shipping papers as "watch sent for repair", when returning the form will say "return from repair", so you will have the correct explanation in case of customs inspection.
Ah pardon me, I live in Indonesia. From my limited personal experience, it's kinda hard to find an honest reputable watchmaker around here. My previously mentioned Tag was serviced by an authorized service center earlier but to no avail. Since that service center can accept shipped watch but refuse to ship it back (I have to get it myself and we live in different city, plus the pandemic makes more difficult to travel), I'm hesitant to send my watch to them again.
Very well, I will give your advice some thought.
I know of at least a member here from a bordering country, if he reads this and is interested he may contact you directly.
Where there's a will there's a way.
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
