Regulating 7s26-36
HI EVERYONE ...I had a Seiko5 SNZG15K1 ...I started playing around with the regulator and bought a timegraph 1000 ... anyways as I was moving the beat lever the hairspring stopped . I removed the spring , wheel and cock and the spring was a mess. I just want to know do these watches come ready to regulate or do you have to turn the brass stay bits on the end that hold the spring ..I think that the spring jumped on mine .but at the time I wasn't thinking straight and ran to disassemble it when I should of looked a bit closer back then ..Thanks Lenny...........
You're not the chap who's selling a timegrapher together with a SNZG15 in Beckenham are you?
All you need to do is check out the photo attached. Start small, buy a couple of cheap used seiko 5's, de-case them, swap the dials and hands and see how you go.
Seiko hairspring are very (insert "very: 5 more times here) delicate. If it is still within repair your best chance is to bring it to a watchmaker to be corrected, otherwise a new balance complete will be needed (out of stock at Cousins at this time). I understand that you are serious having even bought an expensive tool (actually a smartphone app would have been pretty much OK), but to be honest with you I strongly recommend that you practice first with junk movements before moving to the watches that you want to wear or have any value.
I know what I got to do , order a new hairspring balance and try and install it to the cock ... I got to buy an electron microscope now ....Yea I'm the guy in Beckenham ...if I don't sell it quick im gonna have a go ..
In this thread, Steven has a good suggestion for regulating a 7S26/7S36. I've given it a try and while not perfect it's a good start, especially if you have a timegrapher for fine tuning - I don't yet :-(
In this picture it looks like the regulator pin might snag the hairspring when moving the reg arm , is this just a locked gate and the hairspring rides inside so you can regulate without pulling or deforming the HS..... ??
Good picture. No snagging unless you exaggerate rotating. For a beginner it's better to leave it. Discussion:
Well I sold the timegrapher and am bowing out of this hobby , I should have persevered . I could of bought another movement from cousins and swapped it over or try to transplant the balance assembly .. But it's gone now ..At least I know how mechanical watches work ......lol...............
I bought another watch and Timegrapher ,, I regulated the Parnis power reserve and landed on a magic spot , it's running like a Quartz... I can't beleive it ... ..makes it all worth it ..It helps that it hacks so having the balance wheel stopped is a lot less distracting for newbies..When the Seiko stopped I was pushing the beat lever so I think the balance jewel ended up on the wrong side ,, the wheel stopped dead and wouldn't move ..I didn't realize a bit of beat error is acceptable ...
Edited by Lenny
  • Similar Content
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
