best way to flatten case back ?
Yesterday I realized that probably, while mounting the new crystal to my GMT I may have unflattened the case back as in the picture.
I used this kind of screw press to do the job
potenza-forza-chiudi-casse-posa-vetri-a-
and now the case back looks like this, a little pressed inside. The rotor is not affected and is moving freely, my idea is to remove the back and use the same press to try get the thning more flat. What do you think? I wasn't aware this stainless steel back could be so easily deformed.
Edited by chriz74
Yehooooo . As ro63rto saying it would have been best to remove the caseback and movement to do that? You need to find something that has the same shape as the caseback. To press from the inside with?  To even it out? Sure can be done. But!!
23 minutes ago, ro63rto said:
Never had this problem as I've ALWAYS removed movement and hence caseback to fit crystal.
Imagine crystal breaks. Bang goes your dial etc.
That is not possible with a GMT crystal. That's not a press in crystal. It's hold by an outer ring that you press down with an hollow adapter. You don't touch the crystal at all while pressing.
Yikes - sorry to see that this happened. This is not my area of expertise, but I would be very hesitant to attempt to repair this yourself. I can imagine all sorts of ways to make this problem a whole lot worse.  If you do feel compelled, I would first repeat the process you did on a junk case and attempt the repair on that before messing with the GMT. Good luck!
Nevertheless you press in the case with the case back removed. By the way that press is a snap-in case back press, which can be used with some crystals too but only the easy ones. I think your case back can spring back in place but I'm not sure if without any permanent deformation.
I don't get what You are saying. The case back is screw-in not snap-in . Tomorrow I'll see if I can get it back in shape.
I'm saying:   that press is a snap-in case back press.
Well ok, anyway I used it to snap in a crystal on a Bulova with ease and to press the ring holding the GMT crystal. I didn't realize the SS is easily deformed. However it's not a big deal.
And if the crystal is flawed in any way it can still shatter sending glass particles and glass dust into your movement.
I would use the same technique I use on pocketwatch cases that have dents. That is use a wooden dowel that have the edges rounded down, sort of like a baseball bat in miniature. Then  with your hands gently push and roll and push some more, until it's back in shape. Make sure the case is on a hard smooth surface and be patient "Don't Rush It"
Can't happen. It's plastic + the press doesn't touch it at all. The press presses the outer ring that holds it. Please google it.
  • Similar Content
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
