Hi All
Hi my name is Mike. I have just signed up to the forum and just wanted to say hello to everyone. I have Been watching a lot of the videos online. Absolutely amazing.
I just love mechanical watches. And I am now getting seriously interested in knowing more on how they actually work.
Regards
Mike
Hello and welcome from me at present on holiday in LA
This is a good place to get started as there is a wealth of experience and knowledge at your disposal. Also the members are not without a sense of humour (or I would have been chucked out ages ago). I am a hobbyist tinkerer and have gained a lot from membership.
In brief a lot of us start out by getting a simple old very inexpensive working watch from a well known auction site, I would suggest a wind up one, not automatic, without a date or any other complications and basically take it apart and clean the bits in lighter fluid with a soft brush allow to dry and oil as necessary and put it back together.
I don't know what tools you have or how to oil look it up in the forums, you will need some and some cheap all purpose watch oil for this exercise - start buying the expensive stuff when you are hooked and you have a decent watch to do. Take photos before and after you take each bit apart and refer to them to reassemble it. If you get stuck try a trace in the forum and if that does not work post a query. This advice is only for starting off and it gets a tad more complicated and expensive as you move along.
Best of luck,
Vic
Welcome from Miami, Mike, I'm also on a perennial vacation where I live, work and well...vacation all at the same time...in addition to take a break once in a while from this forsaken vacation place by fixing watches! :)
Cheers,
Bob
    • Look carefully at the tube end?? It appears to me to have a fragment thread visible? Either that or a step just away from the end? I can imagine a chamfer, but a step seems odd - but I've never seen the tubes used on these.
    • This is a very valid point and a subtlety that I was unaware of until fairly recently, learning all the time, the video below explains this point well:
    • You don't have to use his special tester. Any good multimeter would work.
    • Yes, it looks like GT Revue 30. Doctor, You can not replace escape wheel by the dimensions You listed. One needs to know much more things like number of leaves of the pinion and it's diameter, the position in high of the table and the pinion, the hight between the pivots, the exact pivots diameter... And then, even if suitable wheel is found, one will need to know how to adjust the pallets position correctly. Restoring antique movements is something different than replacing parts. In older movements parts are not interchangeable, this means spare parts do not exist. Here the case is different, but still escapement adjustment will be needed if a wheel from a donor is found. So may be it will be easier to restore the donor for You...Restoring antique movements usually means making of the parts needed and this requires knowlage and working on lathes skill. In this case repivoting of the wheel is the natural solution, but there is a long way that one must walk untill getting ready for such work.
    • I was looking at Essence of Renata, a chemical used a lot for cleaning hairsprings: "Specially prepared solution for degreasing watch and instrument components. Indispensable for degreasing hairsprings." Looking at the MSDS you can see this is just pure n-Heptane, so could be an option for those who don't want to use the chlorocarbons or hexane?     HF6013 - Horological Essence COSHH Safety Data Sheet Horological Essence_0.pdf
