Seiko 7S26 & 7S36 movement differences
I have been working on a Seiko SKX007 watch for a while. The original SKX007 movement was fairly damaged. Seems like the balance wheel was not tight enough and whoever owned this watch in the past continued to use the watch. This cause the rest of the movement to get scratched and damaged. It is a 7S36 movement.
I bought an inexpensive used Seiko watch, with a 7S26 with the plan of replacing the damaged movement. The major difference between these two watches is the location of the crown. The SKX007 has the crown at 4:00 while the Seiko 5 has it at 3. This causes the day to be misaligned when I install the SKX007 dial.
 As you can see from the first picture, the date is aligned with the crown. But when the crown is placed at the 4:00 position, the date and day at 3:00 is misaligned.
I removed the date wheel on both of the movements. The black one is the original movement. The white is the one from the Seiko 5. The only thing I notice that is different between the movements is the position of the date driving wheel (black wheel on the upper left corner of the movement on the second picture).
Is this what is causing the date to be misaligned?
Same movement. You could take the black datedisc and daydisc from the 7S36 movement and transplant it to the 7S26 and hey presto you have a working movement with the date and day at the right place. That is the only difference. The other is that the 4 a clock watch has a dial where the dial feets are at a different place.
I think I’ve found the answer to my own question. I replaced the Seiko 5 date wheel with the date wheel from the SKX007 and now the day-date are aligned at the 3:00 position with the winding crown set at the 4:00 position. I am assuming the day-date wheels are assembled different for both models.
Yes, that's what I will do. I didn't expect the discs to be different. I hope to get this watch completed tonight. It has been sitting on my box for quite some time now.
14 minutes ago, jdm said:
The day disc is different depending on the crown position, and also between A and B to C versions.printed on them. See below document and compare with P/N printed on the disc.
https://docs.google.com/spreadsheets/d/1sYt_mI9c4tAPiKN3IM8lQx3NEEOyz2DMjVHx5I1_Mqw/pubhtml
There are three different dayrings or maybe more . My head spins around now? Not been drinking no :)
There is a version where the date is at 6H also and crown at 3H?
But in this case it will work to move black disc from the 7S36 to the 7s26 movement?
That is btw a nice part list where did you find that?
Have a few nice 6309 day and date disc that would be great to now in which watch they work?  3H or 4H crown
Edited by rogart63
The disc are different so are the dial? So you must use the dial from the original watch skx007.
I will be using the disc and dials from the SKX007. There is a very slight difference with the alignment of the Seiko 5 which makes the day to be misaligned when the crown is set at the 4:00 instead of the 3:00.
Yes, there are cases with date and and day at 6H.
I did this list, and had mentioned here before.
To move a day disc from a 7S26 to a 7S36 or viceversa, both must be the same version, A and B, or C..
Edited by jdm
JDM,
That is very interesting. I did notice different numbers on the disks. I decided to go with the original disk. Not too bad for a quick movement swap. I am not too happy with the strap, so I ordered a leather one just now. Should be delivered on Sunday/Monday.
I think at some point I will be modifying this watch, but for now it will stay as a diver.
11 hours ago, rodralph said:
JDM,
Nice work with the discs. But i don't really think you got the hands in the right position? It looks like it is in good condition? i Say keep it as is?
Edited by rogart63
You're right. The hour hand is slightly off. I will be resetting them today. It is in very good condition for such an old watch. I really like the look of the SKX007 dial and the black day-date sets it off nicely. I think it will stay this way for a while.
I finally got around to reset the hands to a more aligned position. The leather strap I ordered was delivered today, along with some Silicone grease. Since the watch was open, I greased the caseback gasket and the stem O-ring. I am really liking these thick leather straps.
  • 1 year later...
Hi,
I am facing an issue of day mis-aligned with the date on my 7s36. This watch crown is at 4 o'clock, and part number found on the watch for day wheel was 160287 meant for crown 4H. Am I suppose to use the day wheel meant for crown 3H due to the day /date window at 3H?
No, the P/N is correct for the day disc you must use. How it has happened that it became misaligned, what is that you replaced?
Edited by jdm
I didn't do anything to it, it's been like this for a period until recently I wanted to get it right then removed for inspection. I found out overt the night, in the morning the wheel didn't manage to rotate all the way to align with date. I was guessing the day disc or the drive wheel that has worn, after looking at it seems no damaged. Will the day spring affect the full rotation?
  • Confused 1
    • These are all American movements (with the exception of the "Rubis"), and are all almost certainly "negative set" which means the stem is part of the case. So it's normal that they are all missing- they are with their cases. You will need male square bench keys to wind/disarm them. Vintagewatchstraps has a great writeup on the different systems. But basically, any American "x" size movement will fit any case for that size, possibly with some adjusting of the stem position. With Swiss movements, there is some interchangeability between calibers, usually within the same maker's range, but not really overall- there are thousands of different stems out there.
    • Hi, I'm very new to watchmaking and this is my first time posting here.  I've bought a lot of 10 vintage pocket watches size 0s from e-bay and just got them today.  Most of the balance wheels sprung quite freely and thus seemed like a worthy endeavor as a first batch for exploration.  I've just realized that none of them have any winding stems. Is there any way I could source appropriate winding stems for the movements? There seems to be assortments of various stems selling in bulk on aliexpress, but would any of them fit?  I've read on other threads that some people lathe their own stems (which is waaaay out of my current skill set, which is pretty much nil). Others say that you 'just have to try a few and see if they fit'. I would much appreciate any advice for this matter. Thanks!
    • Nice work.  In the last year, I have been servicing Accutron 218s.  I have the official Accutron hoder that provides electrical contact to the movement.  It is a pretty clever design.  There is a cut in the ring of the holder (shaped like a "C").  When in relaxed state, the holder is slightly smaller than the watch movement.  You spread the cut slightly and drop the movement in and release.  Very clean.  I have made 3D versions of this setup.  Have not explored using it generally for other movements.
    • Double Oooooo   Removal tool? Dreamed of one of these. However, Kalle on Chronoglide showed everyone my system with the pegwood. Worked a treat. Felt so chuffed to be mentioned. https://www.youtube.com/watch?v=tTFrXjiyGKc 46:40 for the wheel removal. Mentions me at 50:00 and does the removal with the pegwood. Felt like my 15 minutes of fame.
    • Sirius. Thank you for helping others with that information. This is why this forum is so good.
