Gothamatic- AS 1250 movement
Hello, new poster here but have followed along for quite some time.  Among my projects is the service of this watch.  It is a bumper movement made by A Schild in the 40's. Apparently this movement was also used by Tudor, so it has a pedigree!   http://www.ranfft.de/cgi-bin/bidfun-db.cgi?10&ranfft&&2uswk&AS_1250
First step is to get the case open.  This is a one piece 'waterproof" stainless steel piece.  Four screws compress the case and crystal against the bezel. Then you are left with the movement and the case.
The crown is "split" which means it should separate to remove the movement.  It is unclear whether you just pull hard on the crown, or manipulate it so that the link lines up and it just comes apart.  I tried yanking gently with no luck.  Manipulation did not help either.  The pictures are from the auction and other sources.
Any ideas?  Thanks!
Wow . A nice little bumber movement? You should be able to take the crown of by pulling hard on it. Found an old Ebay auction that had an similar watch? I see the four screw in each lug. Looks like the movement could be removed from the front? A frontloader?
Edited by rogart63
Hello and welcome from me. Your watch has what is called a two piece stem you can see clearly by your pictures, also the stem doesn't show any signs of rust, you are right the button and part of the stem when pulled should separate and come out. Some can be hard I suggest you are not pulling hard enough. I would always use a pair of nippers to get behind the button and pull. Here is a picture of a pair of nippers, just in case you don't know what they are.
56 minutes ago, jdm said:
Nippers are a cutting tool and better avoided when the goal is not to cut. Use a modified hand puller as in the video, or other apt tool.
Nippers just grab behind the button they aren't used in anyway as to cut. Safe as houses for grabbing a button on a two piece stem.
And presto: here it is!  I used a hand remover/cannon pinion tool; pulled gently and it popped off.
I don't know if you can see it in the pics but the winder mechanism was loose.  There are marks on the case and weight.  Looks like the bridge is held with just two screws.  It started ticking when I tightened it up, so looking promising so far!
Hand removing levers would work. Hand removing tool like the bergeon/presto may be too flimsy.
I use nippers myself but use a cloth to prevent scratching the case.
The main idea is how easily you can control the force. Using the nippers. The force used is not so much 'clamping' the handles but more 'pulling'.
Anil
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
