Stem for 6309
Hello all
I am in need of a stem for a Seiko 6309. The part number is 354601. The Seiko 5 I am restoring had a big dent in the crown but is a one piece. I have a NOS crown, but it's a screw on. I have called all the suppliers I know in the US and checked eBay. EBay has one for $15 plus ship!
Any other suggestions?
i believe a 6319 will work also. it is a derivative of the 6309. as is a 6306 and 6308 - if you can find them.
i'm not sure of what you mean by a screw on crown. they all are.
i have two of them, but they are a bit short to use. they might need a stem extension. it's yours for postage.
Edited by ramrod
i'm confused. it sounds like the OP has a two piece, screw down diver's crown and stem, but he needs one to fit a seiko 5 that he's restoring. the diver won't work.
clear it up, please, OP
Let me clarify. This is not a 6309 diver. It is a vintage Seiko 5 7309-8900. It has a 1 piece non screw down crown that has an o-ring on the stem section. I have a replacement crown which accepts a tapped stem. This new crown has a Seiko part number. The part number above is a Seiko part number for the stem only sans crown. Not a 1-piece stem and crown combo.
    • Many thanks for your advice (being borne in mind at present) & offer Dell. When I was given the clock the plastic anchor was loose on the arbour (it had split at the 'hole') &, after repairing this, I have been trying to determine whether the spindle (pin) should be perpendicular when the pallet is sitting on a flat surface; or whether, when installed, its L-R extremes (or alternatively its tick & tock points) should lie at equal angles from the vertical when moved with spring absent. I can get the clock to run but in every such configuration the top block has to be turned anti-clockwise (from above) by quite a bit in order to be 'in beat' & it always runs fast (despite the pendulum being set to as slow as possible). This makes me wonder if there is any particular feature of/fault in a torsion spring clock which determines which turn direction (if any) is necessary to get it 'in beat'; & whether there would be a different set of settings that would get it running nearer to time at somewhere around the mid timing/inertia position which would then allow tweaking of the fast/slow setting.
    • Now this has happened I bet China or India just to name two will start to produce none genuine parts.  I did. But idiot Boris Johnson failed miserably in his negotiations. The E U stitched up the UK like a kipper. Nigel Farage  offered his help but big head Boris declined. So this is why we are in this mess all because Johnson wasn't clever enough.
    • Hands up all those who voted to leave the EU 😂, oopsie.  UK has just signed the Hague convention, next year that will provide cross border clout to British courts.
    • Ive heard about that oil before for the lever pins. I found it easy to work on , it didn't have a whole lot of pivot wear but i bit sloppy on the lever cock, i think you have to live with what you have or bin it. Stiff to wind and set ?  Not a cannon pinion issue that has no friction thats made up further back and if I remember the barrel drives the hour wheel. No problem on this one .Let me know when you start it as i have another that donated to this one, i can work alongside you with it, two heads are better than one.
