Cracked your watch crystal?
Hi everybody,
Recently I got an Uboat watch (eta 2824.2) in which stopped running.The owner had no idea what could be the cause.
A quick investigation showed that one of the automatic bridge screw came loose & got stuck in the wheel train.
But that was not the only issue. When disassembling the watch I came across more issues:
Broken dial feet, broken pivot in reversing wheel, damaged teeth on ratchet wheel & last but not least
glass
And then I really mean lots of it. Under each bridge I removed there was glass particles to be found.
After informing customer about it, he told me that the watch had fallen quit hard and the crystal got shattered.
He asked a local watch shop to repair it & they just put in a new crystal.
So what can we learn from this?
If your crystal gets really shattered, have a overhaul done because the change of having glass in you movement is quite high.
And to make this thread a bit less boring I have attached just 1 example of glass I found in the movement :-)
Edited by PeterGe
That's good advice. I would suggest having a quick look to see if there had been any damage caused. Many old watches with out a shock resistant and falling on a hard surface you would find a broken balance staff.
Other then the damaged parts mentioned i don't see any damage.
The watch is running again with good amplitude & good timekeeping.
Now I'm waiting for the new parts to arrive to finish the job.
    • I dont like to give up things that i enjoy Tom.  So my next question is how are we going to prepare for that inevitability and what are we going to do about it. Its not just about funding it but I did pick up on something that Mark said once. It doesnt run on fresh air , what if it becomes a burden or an unnecessary cost or for any other reason that i wont get into. We all know life can change in an instant, my life has been so up and down for about 8 years and was only just beginning to level itself out.
    • What I especially like is that this forum is not full of ads. There are some but they're not interfering. No ads between posts like one certain big watch forum. Browsing is also very easy and light for a mobile device. I'm glad there's still room for old school forums like this. I'm a member in many facebook groups but there's really no long term discussion and if you see an interesting post you might never find it again if needed.
    • Hey, Nick! Thanks for sharing your beginning attempts in watch repair and welcome to WRT. I am familiar with the Citizen and the Sekonda. Likely the Citizen houses a Citizen cal. 8200A and the Sekonda a Poljot 2614.2H. I have serviced several of both and made a service walkthrough of the Citizen which you find if you click here. There's a lovely story about the Poljot movement on TimeZone.com called Jessica’s Cornavin Dolphin. Good luck!
    • A perfect example Hector, with the forum we would lose so much more My sentiments exactly Richard, i have experienced  that loss already,  Tiny, Gert, Galilea to name but a few all of which i enjoyed conversations with. I imagine it keeps a lot us sane OH.
