Identification please.
Blacklab
This has just been passed to me for restoration:
Quite acceptable on the outside, strikes but does not run, pendulum missing (may turn up soon), movement very dirty & not signed:
20160530_101706r.jpg20160530_101746r.jpg20160530_101756r.jpg20160530_101812r.jpg20160530_101722r.jpg
Shows serial number 169240 with 18 above on the back plate, 20 on the front plate. Apart from the grime everything seems to be in good order. Any information about the movement (age, maker etc.) would be gratefully received. Also pendulum info would be useful (if the original turns out to have disappeared for good).
Something tells me this is German, I don't know it's just a gut felling. If it isn't German then it would be English.
The case is an architectural form with what looks like a silvered dial with roman numerals with spade style blued hands and what looks to be a mahogany or mahogany type case going by the one and only case picture.
The movement is a 8 day Westminster chime with half hour and hour strike and spring driven. It has a regulator hand blued on the dial above the 12. It strikes on gongs. It looks like an anchor escapement.
Here is a picture of what I think the pendulum should look like. You are lucky to have the original suspension spring as this can be used as a guide to the length of the pendulum rod, but the weight you can only guess, It would be quite heavy. The numbers you have quoted to me doesn't help me in any way sorry.
Thanks for the info OH. Likewise I think its German & may have had a makers name plate screwed above the serial number:
I would suspect that this may have been removed after WW1 due to the anti German attitude at the time, ultimately causing German clocks & other imported goods being labelled 'Foreign'. A quick search for pictures of German bracket clock movements shows similar clocks & movements with missing name plates.
The movement is now stripped awaiting cleaning & I did manage to get it running beforehand. Initial inspection shows no undue wear to the pivots or bushes & no broken or missing parts, so (hopefully) it should be a simple clean & oil. Undecided at the moment whether to re-silver the dial:
I would leave the dial to me its still in good condition. I would go along with that sort of period about the early 1920's.
Here is a good one for you I'm very much into my family tree and on my late Mothers side I found a Bismarck Hambling born 1896, I bet he was popular in the times of WW 1.:D
Edited by oldhippy
  • 7 months later...
After a rather long pause I finally got round to putting it all back together again. I do respect your advice O.H. but in the end I did re silver the dial & frame:
The movement was dipped in Priory clock cleaner & polished as reqd. Reassembly went without any major incident:
Hands cleaned & re blued, new leather pads fitted to strikers, case cleaned with Priory polish reviver.
Before & after:
20160522_231553r.jpg20170121_202225r.jpg20160522_231229r.jpg20170121_202526 r.jpg
Apart from cleaning off the crud on the gongs these were left as is, along with the side & back fabric & mesh grills. Going like a train, gongs & bongs all happy. All in all an enjoyable one, but I am still waiting for the pendulum (which has been found apparently) & none the wiser to identification.
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
