Newbie from Alberta Canada
Kopke
Hi guys, just joined in to this wonderful forum. After looking at watches online and watch repair on on the Tube I got hooked, being a mechanic / technician
I just love the little gears and levers and stuff, how can they ever make it so small ?? Anyway I got a cheap Caravelle at the flee market , took it apart and now
I'm re-assembling . Then, I'll do it again just to get a feel for it.
I'm sure I'll find a lot of info on here , looking forward to it.
Cheers
Hello and welcome to this friendly forum. Plenty on here for beginners and advanced. It might be a god start for you to practice taking apart and the putting together pocket watches there a lot bigger and in many of them the movements are very similar to manual wind watches.
Thanks guys, I guess I have to explore this forum and see what's where to find. Is there a watches for sale section, or
parts , are there any vintage Mido collectors? There you have it, first questions are out !
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
