Trench Watch Ww1?
I'd be very wary of these "trench watches" - there are so many of them out there. They may well be 1910s - or 1920s - or even 1930s. Unless they're silver and hallmarked - or unless they have a WW1 Ministry of War marking (crow's foot or "pheon") on the back, I never touch them.
There's a vogue for things military, and sellers try and cash in on this. Same with "railroad" watches - many are simply not RR grade.
Edited by WillFly
A wise man indeed Mr WillFly, thank you, I will check this out when I see the watch in my dirty little mits, I've only seen these photos of it.  Thank you. :thumbsu:
It appears to have a base metal case and the movement looks very basic and cheaply made. I cannot see a makers mark or serial number on it either.
If it runs and you like it that's fine, but I wouldn't pay much money for it.
Sorry to be so negative!
I think you need to make a distinction between a watch worn in the trenches and a military 'issued' watches.
In this case I can imagine this being a personal watch of a soldier in the trenches as opposed to a watch paid for by HM govt and issued to a soldier.
Whenever I see these old watches I always think back to how old my ancestors were at the time... In this case assuming it came from 1915, my grandpa was only 10 yrs old and there was no electric supply in the village he grew up. He only saw the first motor car when he came to a bigger town to work in 1922!
We tend to look at watches as part of life today but in those days they cost a bigger chunk of their salary ... a different time.
Wear it and enjoy the sense of history... but don't pay too much for it.and don't expect to make money from selling it!
Anil
Good points, Anil. In fact, I'd go even further. There's not only a distinction to be made between a real trench watch, i.e. one used in the trenches, and military-issue watches, but also between real military-issued watches and non-military watches with a military styling and design. And, if you want to complicate matters even further, there are watches which were bought by the War Department and engraved with military markings - but never actually issued and then sold as army surplus. Ebay is riddled with all these categories and it can be a minefield to sort through when looking for the right article.
The point that I was making is that you see lots of these "trench" watches on eBay, and part of their selling/marketing play is to cash in on the current vogue for military watches, and for WW1 timepieces and militaria in particular. Many of those advertised as such are simply not - and they're a con. This is not to say that they're not decent watches - they may well be - but they're being offered under false pretences and sometimes at inflated prices. That's why I'm so picky about what I buy - and I never buy to make money, just for the love of the item.
Edited by WillFly
Just to add a point: Here's an example of what looks like a perfectly decent watch currently for sale on eBay:
Auction no: 161312302077
Probably 1920s - no idea what the movement's like as there's no pic or description, but there's no false advertising in the auction here - no "trench watch" or "WW1 watch" or "Officer's watch" - which you see all the time - just a straightforward description of what was quite a common watch of its period.
At the risk of being boring or over-egging the pudding, here's an eBay item for sale described as "Officer`s Trench" Swivel Lugs Enamel Dial BUREN Wristwatch circa 1914 -1918"
Auction no: 151308395053
Not a shred of evidence in the watch itself for the usage or the date. That's what I mean by misleading advertising...
Edited by WillFly
  • 10 months later...
Hi, new to site, seeking help. Have a watch just like member DMS from Milton Keynes who asked for aid in May 2014 re. a ww1 era wristwatch.
Don't know much about it except it runs, hands turn, but they won't adjust as winder won't seemingly pull out to release them.
My question is - there is a separate button beneath the winder - does anyone know what this is for - I have no idea how to use the watch if there is some sequence or trick to adjusting/resetting the time?
Thanks in advance
Neil
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
