How to open an old Elgin pocket watch?
wow,  nice chart, i copied for referance.  with some minor math  you should be able to select the amount of dome on a hunting case acquired with no crystal.!  measuring  the opening in the bezile accurately is the next step.  good luck.  vinn
Well it's been awhile since I worked on this one. I thought I was nearly done, having finally found a crystal. Thanks to whomever mentioned Dave's by the way!
Anyway, I pulled it out tonight to measure for the crystal and I noticed that will the balance wheel was beating and the second hand moving, the hour and minute hands aren't. It appears the other wheels are engaging and moving but for some reason the hour and minute hands aren't moving. Back to the drawing board this weekend! Any suggestions?
  • 9 months later...
OK I know it has been awhile but I have an update with a question. I have received another crystal that I am going to try and fit today. I pulled the watch out the other day to remeasure, gave it a wind, and the second-hand get running right away. However, I noticed two things one which seems very unusual. When winding the watch, the minute and second hands turn. That seems strange. When pulling the lever to set the hands, that seems to work properly except once I have it set and push the lever back in, the second-hand ticks but the hour and minute hands do not move. Hope this makes sense. I was really hoping to have this one finished today finally but it looks like I am having bigger issues which are going to require a strip down again. Any advice would be appreciated.
  • 3 months later...
Well I know this is a very old thread but I'm going to finally attempt to finish this this weekend. I believe I have found a crystal but before putting it in I'm having some issues. While the second hand is moving and appears to be operating as it should, the minute hand is not moving. Also, with the lever pushed in, the crown will still turn the hands while winding. What could be causing these issues???
Sent from my SM-N900V using Tapatalk
It sounds like a cannon pinion issue.  Has it been snapped back in place properly?  If it has, it could be needing tightened.
I'll take a look. Was hoping to have an idea before I broke her down again. Thanks Geo that gives me some direction. I'll let you know what I find.
Geo everything appears fine unless I misunderstand the function. The center wheel turns the Canon correct? Is it possible this is not happening because it fits too loose? Does there need to be a crimp or anything to hold it?
The cannon pinion should be slightly tight on the centre pinion to allow slippage when setting the hands, but tight enough to allow the hands to be driven by the pinion.
Have a read of this thread it may help you.
Geo I actually found the problem. The lever that pulls out to set the watch actually had a loose screw and so it wasn't actuation the way it should. Tightened it down and now she is working ok.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
    • I would like to see the movement. The watch is the movement. Anyone can print a name on a dial and sell it as "the maker".
    • Thanks for your answers! There seems to be a contradiction between these two answers, so perhaps I need to clarify. The flat and convex jewels look identical on the side facing away from the pivot shoulder. That is, there is an oil reservoir. I don't know if that changes anything but I thought it was safest to clarify since I didn't include a picture of the jewels from the opposite side.
