OSSO wristwatch stops and runs
I am servicing a wristwatch named OSSO for a friend. The movement is Felsa cal690 automatic. 25 jewels Bidynator.
I see something strange here I have not seen before.
When the watch is face up it stops after 5-30 seconds. If I flip it over, face down, it starts automaticly. Then I flip it back to face up, then it stops.
Ideas?
DJT2: Thank's. I'll check that. I will check the top jewel when the watch is facing down (the balance cock jewel).
Vinn3: I did, during service, removed the balance from the mainplate - and it looked fine. BUT i did not (come to think of it) include the balance and the balance-cock in the cleaning liquid. And I did not remove the jewel itself and inspect it isolated.
A new day, with new knowledge. This is going to be a good day! :-)
Hi Tin Tin, since you did not clean the balance jewels that would be a good place to start.. did you dismantle the balance jewels in the mainplate?
While you have the balance off..inspect the pivots closely.... it may have mushroomed or bent.
Anilv
