ETA 2551 Service by Beginner
Hi everyone.
DISCLAIMER: This is a post of a very beginner in watch repair. Hence this is by no means a description of how to service an ETA 2551 movement.
OK. Now that this is clear I can start this thread, without being liable to whatsoever B)
I happened to found a selection of different movements from ebay that someone wanted to get rid of. Among these 18 movement (won't tell you that I paid a mere 40 EUR for all of them). Although they are quite small they are excellent to train my skills.
Most of them came with a dial and hands but no case. Even the stem and crown was missing on each besides one which is fine. I need only one for my exercise.
I started with a 2550 where I immediately saw that the hairspring was somewhat faulty. It turned out it was broken. So I used this to get a first impression of the movement. I wanted to reassemble it but it turned out that also the setting lever was broken. So I keep the parts as spares.
Back to the 2551. It is an old movement that was built between 1965 and 1972. It has a date complication but no second stop. Pretty straight forward. I was able to find the BOM from ETA somewhere in the web but no oiling chart. I will look at my 2824 oil chart. Should be similar and this is about learning. I'd like to see it running again after cleaning, lubricating and assembly. It worked before disassembly.
Here are the first pictures of the two sides before disassembly.
After taking the initial photos I started with the disassembly. I take a picture pretty much after every step, e.g. taking away the gear bridge and after literally every gear. Since these are a lot of pictures with very little difference I show only the most important ones.
This helps me if any doubt appears to get it assembled again. I upload them to Dropbox and use my smartphone on the workbench to look at them from time to time. Very convenient and a big help during re-assembly.
Here we go disassembling the date mechanism.
Thanks Bob, but why "anxiously"?:)
I actually did all the steps a couple of days ago. So the pictures come in now very quickly.
What I should mention is that one of the most important photos is the first of my last post. Here you can clearly see the position of the Date Jumper with its spring. BTW it took me 1h to get to this stage: 10min of taking away the parts and 50min under the workbench looking for the da... date jumper spring!:pulling-hair-out: I'm sure I am the only one crawling under the workbench looking for parts.
Next: disassembly of the different date wheels, setting wheel, pawl winding wheel etc. and the automatic assembly.
I should have done the automatic assembly first and then take away the balance wheel / balance cock. I'd like to have the balance out of the way as soon as possible. There is a certain risk of damaging it when holding the movement in the movement holder.
Next is taking apart the balance, pallet fork and train gear. BTW this was the first time I saw the left-threaded screw of the crown wheel with the special marking I read about earlier. Two extra slots left and right.
I should have taken apart the crown wheel, click and ratchet wheel first. But OK. Next time. I should prepare myself a little checklist.
Edited by AlexanderB
Turning the movement once more I started to disassemble the keyless work. I always take apart the setting lever although I heard often that watchmakers leave it in place for cleaning. I found it not too difficult to screw it in again what I use a big chunk Rodico that I use to hold setting lever and plate together and then insert the setting lever screw.
That's it for the time being. Parts are already cleaned and I spent another hour looking for the lower incabloc under the table. I need to practice a smoother grip on the tweezers. But this will come. BTW I use Dumont #3 or #5 Dumoxel here.
Don't feel bad about the spring adventure under the bench!! I can vouch that most of the watchmaker time is spend there! Just talking by experience! :D
The funny part is when the part is not attracted by the magnet and is the last one to finish the watch!!!
Your pictures are awesome and I always learn from walkthroughs so much even if I have worked on the movement before...which in this case I haven't so double the treat!
Thank you for sharing!
Cheers,
Bob
Only last night I spent an hour searching the floor for a spring from my poljot alarm movement I'm working on at the mo only to find it stuck to my rodico. I had to have a lay down after to calm down. :D
I once lost the date spring from a Poljot 3133 chrono movement. Never did find it. I ended up making a new one and then lost that one too. Fortunately, I found it a few minutes later, stuck to my shirt.
Edited by svorkoetter
Typo
That's hilarious! But I got a good one, I lost the little spring that fits in the hole of the bezel in a sub. It goes in under a ball/pellet? and make the bezel ratchet....I didn't even bother, I got a spring bar and made another! Then the pellet got lost...no problem, I destroyed 3 ball point pens until I could get one pellet that won't run away...Job done! :)
OK, back to the OP! :thumbsu:
Alexander, you will find that Seiko marks the screws too in a similar way...but different. You will still recognize the marking of course.
I believe (again not familiar with this movement) but you will find the jewels may differ in either diamether, thickness or both when comparing the top with the bottom. Even if it takes a little longer, I would not mix them...probably do them separate just in case...they are so small!!
I wouldn't clean those in the ultrasonic or in any machine...dip them in benzene/Ronsonol/lighter fluid, for a while and then check them for dirt. Give them a very personal treatment. That way they can't get lost...although there is always Murphy's Law: "Whatever can go wrong, will! " BTW, I do the same to the hair spring now... I used to put it attached to the main plate in the ultrasonic but don't anymore. You see, I don't deal with volume so I can take my time, being a hobby.
When you put the parts -- especially the tiny ones -- in the baskets and after the clean, inspect the basket with the loupe...some get stuck in there and you can easily miss them later. One more reason not to put the jewels (and all its components) in those too.
Thank you folks. This way I can get at least something back to you all.
Bob, I thought the same. For the balance and hairspring I now use Bergeon One Dip (No. 2552). Regarding the basked: I know! I once overlooked a tiny screw. As I realized that it was too late: since there was water involved the screw was totally rusty.
There are a couple of learning experiences in the meantime:
1) Don't ever rush things and move slowly. I once moved to fast and knocked on the workbench and the parts flew all over the place...
2) Keep order! When I put the parts in the little baskets for cleaning I combined some groups. Ended up in a mess. I got myself more tiny baskets and it happens that I for instance put in there only the train wheel bridge plus its two screws.
3) As you mentioned Bob, after emptying the baskets I triple-check with the loupe that they indeed are empty and no spring or screw has hidden in come corner of the round basket.
4) STOP working when you feel some restlessness. You'll mess up for sure. I now stop after I see that I make more than one mistake in a row. Also see 1).
5) RELAX when using the tweezers! Just very gently. Breathe out. Force yourself not to force it. Cool, cool, easy, easy - DAMN! Pushed too hard again. Be right back. Find me on the floor.
Cheers Alexander
Added 5)
Here we go.  Lubricating the lower incabloc (actual the plate incabloc) was a challenge in itself. I never did this before. Saw a video somewhere and it looked so easy: put a tiny little drop of 9010 in the middle of the flat side of the cap jewel and let the lower part fall on it. The cap jewel will hold due to the oil.
Well it took me at least five attempts to put a drop of 9010 on the cap jewel because the oiler always sticks to it. So I happened to clean the cap stone again and again. I got a little nervous and violated rules 1, 4 and 5 (see above) ending up on the floor another three times although I myself gave the advise to stop when parts start slipping from the tweezers.
I hope you will use my rules unlike me.
Anyway. Now I got it done and the jewels are in place again. Uff!
Cheers Alexander
Cheers Alexander
P.S. I added the 2Ct (my 2Ct BTW) for those who just lurk in and have no idea of what we are talking about. We are talking about really, really small parts!
Sorry for duplicating the post. Wanted to edit it. Anyway.
In now installed the setting lever. This is how I did it:
  1. Place the setting lever on the plate.
  2. Grab both the plate / setting lever with Rodico.
  3. Insert the screw.
  4. Repeat steps 1 to 3 until you manage to tighten the scew.
In my case it took five attempts. Here are my 2Ct again. The movement is actually smaller than a 2Ct coin (EUR).
Last for today: finished the keyless work. Thanks to Roland (Endeavor) in the neighbor thread about the ETA 2540 I decided to assemble the stem, clutch wheel and winding pinion first. What a fiddly thing to do. But I eventually managed it. Then the yoke and its spring (managed not to crawl on the floor!) and finally the setting lever spring. Everything lubricated with D5. Did not use grease here.
BTW I use a slightly angled perspective when taking the pictures. This lays emphasis on the parts I was working on. The last picture was taken with an aperture of 5.6 which leads to a slightly blurred background. Visit my photography threat for more details on this.
typo
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
