  • Similar Content
    • By FitOutPost
      Hi, my name is Ross. I am a rookie watch enthusiast and I am really puzzled here.
      Could someone explain to me what kind of a problem am I facing with my timegrapher?
      I do two sets of measurements with the same watch (1 day or 6 days apart) and receive vastly different results - to the point of being completely different from what I observe in real life.
      For example, my timegrapher shows that my watch is running fast (or ahead of time), while in real life I observe that it runs 7 seconds per day behind. I even recorded a video about it so you could see it for yourself: https://youtu.be/mhGzf6aLMlY
      How should I interpret that? Am I doing anything wrong?
      Problem_with_Timegrapher_-_Knowledge_Sharing__16.mp4
    • By east3rn
      Hello.
      I am working on a vtg. Citizen cal.7520 automatic movement.
      I have put the watch on the timegrapher
      The graph looks OK but the beat error shows 9.9ms. I presumed that beat error should be around 1.0~2.0 given the shape of the graph.
      Is the beat error actually bad or the timegrapher is wrong??
      Thank you!
    • By Padd
      Hello Everyone,
      Padd here from the UK.
      It all started with a desire to fix a Submariner replica I bought off a lucky lucky man in Pisa, Italy while on a European tour.
      Next thing I know I'm investigating Submariner replicas and building my own, signed by me, using a Seagull ST2130 movement, adventure watch.
      Now I'm hooked, I took inspiration from Marks videos, now I'm happily starting to work on parts of the movement, and have recovered one or two movements where the stem came out, but wouldn't stay back in. I have built a few watches for friends and relations, but now I need to be able to service them when they come back to me.
      I also have a couple of movements that run really badly, so I will be practising on those over the winter weekends. Full repair/servicing kit IS my Christmas present.
      I really want to get one of those ST2130's, serviced and tweaked by me, doing a -------------------------- on my timegrapher. not a -.'-.'''--,'.'.' (and worse) that they do at the moment.
      I wont start to list my watch collection, but it runs from a Casio digital to a Rolex pocket watch with Seikos, Citizens, Omegas and home builds in the mix.
      Must do Mark's course, but I'm afraid I may have already learned 60+% of it already.
    • By PJA
      Just in case, I came across this "Watch-O-Scope" software. To those who have a need for it. Also here is an instructional video how to install. I hope it will help somebody here.
    • AS Watchweasol said..To remove the springs you HAVE to let down the power on all the barrels before doing anything to this movement, as I found out when I first started the hobby many years ago. If you have never taken a movement apart before, this is Not really the best movement to learn on. Hope all goes well for you.. Len
    • Hi  like jdm  I also have one of these chinese versions. Ok its not bergeon but it doe's the job. Like most things in life the justification for the expense is based on how much use is it going to get.   If you are opening lots of watches on a regular basis and want precision then get a bergeon if not then these are adequate .
    • Fleabay? Pejorative  term for ebay through out the English speaking  world.
    • I think that can be caused only by the square pieces that hold the bits to be different height, and/or the bits themselves to not be accurate. It should be correctable without any special tool. Check that the square parts mentioned above are assembled correctly, that is they are inserted on the same turn of the threaded bar. Also, avoid tightening their knobs, so they can align better.
    • Check this thread:
