Finally got my lathe set up!
jnash
Great setup.
I have been using a Sincere Clocks chinese lathe now for about three years and have not regretted buying it for one minute (get it).
The only thing I stopped using was the motor - it's not variable speed. So I purchased a cheap sewing machine motor with foot pedal and that does the job well.
I have been meaning to use the motor with another lathe I own (lorch) but never gotten around to it. The only other thing I had to do is open the bore up a little as some collets were extremely tight fitting. I was very careful not to touch the cone part when doing this and the result is perfectly fitting collets, with no noticeable run out.
For the money - you cannot beat this lathe.
Very nice! I was tempted to buy one of those, but never did. Looks good and I would like to hear and see more about the Sincere lathe. Have you thought about sending some pictures to Tony at http://www.lathes.co.uk ? As it looks like the Sincere is not yet there.
On the drill press picture. Did you use the clamp on purpose like this? Supposed to be the other way round.
Regards
Dirk
That's a nice looking lathe Johnathan, I particularly like the large easy to read dials.
I hope you didn't use the clamp in that configuration to hold the brass disk fir drilling as it's the wrong way round.
Great setup.
In regards to the motor, I like this one bit you are right the speed is an issue, I was thinking some form of dimmer on the power cord might allow me to use this, I have limited knowledge when it comes to electric, maybe that will work?
Sent from my Nexus 5 using Tapatalk
I tried it with a foredom foot pedal and it doesn't work. Only on. Or off. No variable speed. And it looks identical to mine.
If you manage it though please share your method. I would be very interested
Its up and running and looking good. You have it in a nice light room, you might find you might need better light when working on small pieces. I don't know if I would have wanted to work on that lathe back in the 70's and 80's with all those belts about when I had long hair.:D What do you want to be able to do on it.
Its up and running and looking good. You have it in a nice light room, you might find you might need better light when working on small pieces. I don't know if I would have wanted to work on that lathe back in the 70's and 80's with all those belts about when I had long hair.[emoji3] What do you want to be able to do on it.
Thanks , this is actually my office, this will be upstairs with my other watch stuff, just working out the best place for it. With a lack of garage (which is now half of my new kitchen ) I have to find somewhere to work without ruining the white walls with oil and mess etc..
How to start practising sharpening gravers !
Thats annoying, maybe my idea of some form of dimmer switch will not work then! - i havent seen a motor like this with arbours on both sides!..
This may be a waste of money then!
Definitely no accuracy certificate but others have done everything watchmaking needs with it. Also this lathe is cleaned up and sold as vector Lathes, vector Lathes are apparently used in watchmaking school... That's good enough for me :)
slight negotiation, and your have to ask them to be creative with the customs.. i sold my original lathe so i could purchase everything. i have other attachments and indexing plates aswell.
I did a lot of research on my own and with the help of others and it worked out quite well.. i have no excuse to blame my tools this time!
  • 3 years later...
On 4/10/2016 at 7:42 PM, Mark said:
Great setup.
Hey Mark, please share with us about how did you open the bore?
I am a newbie I do not understand what run out means?
I am thinking of buying Sincere lathe and similar setup.
The procedure would help a lot.
It means to bore slightly the part where the collet goes. It can be done on the lathe itself. I suggest that you get a lathe first and worry later about what, if anything, has to be adjusted.
BTW we have a section on the forum  where it's considered polite to introduce oneself before asking questions.
Thanks for advise jdm. I introduced myself :)
  • 4 weeks later...
Hi folks,
Please share your experiences of using Sincere lathe & accessories.
I read some negetive reviews about them having a lot of grit and accuracy issues (These are more than 5+ years old posts though)
I would like to know your opinion and first hand experiences with these Sincere lathes so, I can go ahead with confidence and buy them.
Thanks in advance.
Best regards,                                                          Sid
It is positive opinions anywhere you look. Here we have a(t least) David and our Host Mark having one. Other forum says the same.  I researched and posted a listing summary of all the variants, bundle options and accessories. However just like with any tools what can be done with it depends more from the person using it than the bare metal.
Mark's experience of having to open up the bore the fit the collet is about the most negative testimony you could give, imo.   Mark's a positive guy so was very kind to them overall, but that is an fail.... I mean whats more important than bearing and collet fit?  They should be done properly to very fine tolerances to get a passing grade.
I've not owned that make but have owned a dozen other lathes and the collets always fit perfectly
Edited by measuretwice
Good point, now to keep things in perspective let's look at the prices of some new horological collets.
20 pcs set Sincere, $262https://docs.google.com/spreadsheets/d/1d-eiO04y72L-BtWxkXPAySAazyTfYFGE_6A73yMo2KI
20 pcs Cowell, you have to buy individually http://www.cowells.com/pricelist.htm
(1 x £179) + (2 x £169) + (2 x £105) + (15 x £92) =  £2,286 + 20% VAT =  £2.743 = $3,519
Hi JDM,
This is super consolidation work. Huge help.
Thanks very much.
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
