New additions to the K and D Inverto staking tool reference site
I also just realized I had that tech bulletin saved...but in French for some reason 🙂 No, I don't speak French. 2172_Bulova 11AOAC 11AOACD 11AOACB.pdf -
By steve1811uk · Posted
Thanks for the replies. I did the job today and found that the oversized stem fitted just perfectly into the worn mainplate without any adjustment. Original stem diameter was 1.24mm and the oversized was 1.40mm. I did have to make an adjustment to the setting lever though. The small pip that engages with the groove in the stem hub was slightly to wide. I made that a bit smaller with a fine file. Don't ask me why that was too big, it just was. All working very well now. No wobble and not pulling out. New crown fitted as good measure. -
Hi Vandan. Hi from a fellow newbie! Marshall has got a lot to answer for hasn't he! 😄. I also got hooked to this hobby after watching his videos. Good luck with your journey to service your Grandfather's watch. Nick
Hi all, I have a lovely Favre-Lueba dress watch from late 70s/early 80s in a stainless steel case. Its an unusual curved rectangular case and crystal. I'm wondering if there's any possibility I might be able to buy/find a replacement crystal for this watch. The base of the crystal is also curved to match the case, rather than flat. I'm looking at the Cousins website page here https://www.cousinsuk.com/product/rectsq-rounded-corners-one-side-curved-bezel-sternkreuz-rzr but not sure if I'm looking for the correct type. In my case its a rectanglular crystal with rounded corners, and both the upper and lower surfaces of the crystal are curved. Update - OK I now think I know what I'm looking for, but Cousins don't stock the size I need :-). I think I need a Sternkruez RZ 315x220R9, acrylic, cylindrically domed with rounded corners. Any tips or alternate sources for this type of crystal? Many thanks
