Wrong tool for the job
Tonight I ran into a problem winding a left handed mainspring. My mainspring winders are all right handed winders. Luckily, I have two winders in the size I needed. So I wound the spring into one, then carefully pressed it out into the other. Then into the barrel. Not ideal, but it works in a pinch.
I remember that Marc posted a simple but clever (to me anyway;)) suggestion last year on this. Have a collection of washers in different sizes, then it doesn't matter which way your winder goes. If you need to change orientation it you can transfer the mainspring to a washer, flip it over and press out. Saves having to have spare winders or buying another set going the other way.
Stephen
Stephen
That is a good idea, too!
That is a great idea. Thanks
Stephen
Don't understand
14 hours ago, jdrichard said:
Don't understand
Simple. If you only have a right handed winder but your spring needs to be wound left handed, wind it up right handed but instead of installing it into the barrel, install it into a washer. Flip the washer over and then press it into the barrel as you would a new main spring. obviously the hole in the washer needs to be slightly smaller than the inner diameter of the barrel.
Got it, thanks
Moved to Tutorials & Information section :)
Good tip - thanks for sharing.
9 hours ago, Folkvisor said:
I recently found this on YouTube: Servicing an IWC FA Jones watch.
I can't find it on the videos on this site. Just wondering if it's there or will be put up soon. It's a beautiful watch and a very good video.
Dave
Lol - very big change in topic from "Wrong tool for the job" apologies to the OP.
@Folkvisor, I have added the video now:
Your solution to reverse winding was simple but affective like all good ideas.
I'm supposed to take the mainspring out of my 2836-2 movement by hand, clean it, lube it, and put it back by hand. I can see all sorts of problems with this. One of the main problems is that my hand would contaminate the spring with the sweat/oil from my hand and make it susceptible to rusting, etc. So, I'll buy a winder before I attempt this manoeuvre.
I have attempted to wind a couple automatic wristwatch mainsprings by hand. But never been successful. I can't get more than a few coils wound in before the while thing explodes in my hands(twss). I gave up trying and found a cheap set of used winders on eBay.
But what about the opportunity to exercise the very thing that makes human hands such miracles of evolution - the ability to apply immense forces (clamping that damned bridle against the barrel wall) while dexterously holding a 10mm object and a loose, floppy spring end, and simultaneously winding and guiding the spring into the (virtual) center of the spring? Only to realize that you've wound the thing in backwards...
So on the other hand, humans also invented tools so that work was easier and more productive.  Buy the winder, Folkvisor...
Drat, can't "wriggle out of the crushing grip of reason" (Calvin and Hobbes quote, for those that are fans).
When done with the barrel on the bench is not that difficult. However as mentioned before it's better not to to manipulate the hairspring with bare hands.
Edited by jdm
You make hand-winding sound almost appealing - or was that appalling? LOL
I even read Calvin and Hobbes in French; everyone needs a hobby...
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
