  • Replies 408
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
I've given up on the idea of a comprehensive, affordable set of mainspring winders. A new spring is cheap and goes in so easily! By no means am I  an expert with hairsprings, but repairing them i
You wouldn't. It's about barrel sizes. The ETA set is sized (and I'm sure labeled) according to common ETA movements. Generic sets are sized by unit measurements (mm). If you do a lot of ETA stuff, it
Just found in a chronograph barrel. Apparenly put in by hand, too ? Frank
Posted Images
9 minutes ago, richiesgr said:
Is it ok to ask why ?
Sure, it is ok.  Have not invested a lot of brain power into my choice. I always pick the K&D winder because: 1) it is well-engineered, 2) adjustable, 3) always works for me,  and 4) it in the front of the drawer!!  Why my dad bought four different sets of winders is a mystery to me.  I do not recall which one he used regularly.
If all I had were the Master-Craft, I am sure I would be happy with them.
Link to post
14 hours ago, LittleWatchShop said:
I have one of these...never tried it.
I have one also, and it works best for wrist watches, but it does work well once you get the hang of it.
Link to post
I have used both the K&D and Watchcraft styles. In my opinion they both are unnecessarily finicky. In addition to this it isn’t unusual to find that these kits have hooks that are almost unusable. They are almost useless for automatic and modern mainsprings. They have caused me a lot of frustration.
If I could give any advice I’d say buy a complete and new Bergeon set if you can afford it. They are beautiful to work with and make the process seamless. Wish I bought mine much earlier.
Cheers
Link to post
If you are referring to used Ebay purchases...I would generally agree.  However, I have found it relatively easy to refit the winding arbor with a new pin.  I drill out the old pin and turn a new one on the lathe and then insert it.  Without a lathe, this might be a challenge.
Link to post
An ingenious tool from a vanished past. It is amazing how the folk of those days used to think and build tools. I bet with enough practice you could use this for any spring size.
If someone like me made a mistake while winding it, would it hurt? Likely to happen multiple dozens of times. Someone like me as in a person of very poor skill.
Link to post
    • Yes it can;  perhaps impulse jewel can't enter the fork horn, if the shock has  knocked a pallet jewel out of alighnment or bent a pivot. Remove the two black screws then the automatic device, loosen the cock screw by couple turns, raise the bridge just enough to pass the impulse jewel over the fork so to get impulse jewel inside the horn, tighten cock screw. It will run, however , might get stuck again if pallet jewels have got misaligned or a pivot has got bent.
    • A little uninspiring.  It does run though...kinda.
    • I decided to find a knew winding pinion for my Vulcain.  I see some wear on the one I have.  I have the spec sheet on the Vulcain 120 and identified the part as #1246.  I searched around and found scotchwatch.com had one.  $45.  I really want it, so I bought it.  Meanwhile, I continued my search and found a part with a different part number (410) on Northern Watch & Clock Supplies in the UK.  It was just a couple of pounds, so I bought it. Later I looked at the invoice from scotchwatch.com and see that the part I bought is 1246 (410), so I think the part has two numbers.  Well, we will see when they arrive.  On part cost 20x the other one.  I am not complaining...as I am glad that someone takes the effort to maintain an inventory for budding watchmakers like myself.  I just think it is interesting. Learning new things every day.
    • Thank you for your introduction and welcome to this friendly forum. A nice looking watch you are wearing.
    • The hairspring is partially blocked from view by the autowinder but looks to be ok.  The balance swings with a puff in one direction but not the other.  Could it be the position for the impulse jewel and fork?
