I fully let the power down. Turn the barrel by finger, you get a feel of the torque the movement takes to start running . That would give you an idea if you get inadequate torque out of both spring( unlikely). Next check turning( by spoke) wheels of the train. Make a habbit of this tests to get the hang of it. I didn't get to read all said so far, but agree with JohnC. 1-Oscilators grously out of beat wont self start. 2- Bad pivot. 3- Fork pallets badly out of adjustment. 4-No end shake on staff, fork arbout and escape wheel. Make a habbit of checking the oscilator, See if pivots jump out of jewel holes as you gently raise one side of the balance wheel. Good luck
I'm waiting for the interview you had with Donald Trump.
By HectorLooi · Posted
if you look at your original post, the 3rd photo shows that not all the wheels are clustered against the front plate. One of them is reversed with the wheel against the back plate. As a general rule, the gears are always arranged with the wheel to pinion, wheel to pinion. I think that wheel upside down. There might be some confusion here. We are not talking about the centre wheel. The going barrel is counted as the 1st wheel or sometimes called the great wheel. So the 4th wheel we are referring to is the one before the centre wheel. -
I think that unless the mainspring is badly deformed that is unlikely to be the issue. If the rundown of the train is okay - or at least not awful - most likely problem is in the escapement or balance wheel. Check the hairspring is not hung up on the centre wheel - easy enough to do and easy enough to miss. Also check the hairspring is not out of flat and rubbing something.
By MechanicMike · Posted
post script: the view of the larger pivot, red arrow, is where I suspect a spacer, or the two washers that were directly behind the cannon pinion might go, to provide clearance between the two wheels. but I don't know. anyone want to loan me their 1950 Kundo 400 day clock for a reverse engineering study with me? 😉😁
