4 minutes ago, jdm said:
One really can't do watch work without vernier calipers, and is some case a micrometer.
I don't need them at this moment, I'm still learning to walk. But I will need to get some now.
Link to post
  • Replies 408
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
I've given up on the idea of a comprehensive, affordable set of mainspring winders. A new spring is cheap and goes in so easily! By no means am I  an expert with hairsprings, but repairing them i
You wouldn't. It's about barrel sizes. The ETA set is sized (and I'm sure labeled) according to common ETA movements. Generic sets are sized by unit measurements (mm). If you do a lot of ETA stuff, it
Just found in a chronograph barrel. Apparenly put in by hand, too ? Frank
Posted Images
Up to you of course, on my reasonable order of priority watch repair tools a  $15 digital calipers come much before than multi-hundreds winder set.
Link to post
I'm trying to concentrate on tools that I need to use to disassemble and assemble a watch movement for now. I know calipers are not expensive but it’s not needed it for it.
I’m trying to work out whether the set of mainspring winders is what it should be or whether there is a problem.
  • Confused 1
Link to post
I had a good look at it when I got home and they come in pairs: 00/0, 1/2, 3/4… 13/14/15 the arbor diameter is the same but 15 has larger ‘cover disk’ than 13 and 14.
From what I can see without measuring it, the arbor diameters and the disk diameters are the same. If you were buying it separately and you need, say 7 and 8 winders (they are different diameters), you can take your pick and buy 7 or 8 arbor/crank for the two winders.
I think this is how it’s intended to be. I don’t know why and I don’t know how Mark managed to get the spring on the size 11 arbor, but it is a clone and he probably disassembled and assembled the going barrel several times and that possibly stretched it a bit.
The pics below, the arbors are from left to right 3, 4, 5, 6, the others are 11 and 12 and I swapped the arbors, you will see the numbers on the winders and the arbors, see how it overhangs on the no 11 winder even when swapped. Also a picture of No 10 arbor in no 11 winder.
I thought the newer 17 set might have been different but see the screenshot from Mark’s YouTube video (light wood colour box) and you should be able to see how they overhang as well. Of course I can’t see the sizes of the arbors but I doubt it will be different.
Link to post
Lots of questions about these, no dedicated place for conversation and answers so I’ve created this thread!
I am learning to repair and service pocket watches and have been looking for mainspring winders. From the comments in several threads it seems;
- they are expensive
- a lot of hobbyists wind them by hand
- professionals will say never do it
- there are not a lot of posts about the different between a pocket watch and wrist watch winder
- there are some posts with brands and sizes for pocket watches
- no info I could find about what to look for and what to watch out for when buying one
I’d like to buy one so I can avoid destroying the mainspring by winding and touching it. I’ve found several online selling for between 15-$70 dollars like this one. Good idea? K&D Robbins type
Link to post
The antique winders seem to never really work well. The modern ones work a bit better. I'm a professional and wind 90% in by hand, and defy anyone to look at two springs, one wound in by me by hand and one by winder, out of barrel, and tell which is which. Winding in by hand does take skill though. In some cases a winder is really the only good way to do it.
Link to post
Hello Rexxus.
i too started on pocket watches and started winding by hand.  i understand most professionals, of which I am NOT one, consider it bad practice.  However, what works, works!
i stopped doing it by hand simply because it hurt my fingers to do so and I had been slapped in the face 137 times too often by particularly cheeky springs.  I bought the model in you picture years ago and love it.  There are two main drawbacks IMHO.  1. As nickelsilver suggests, the older ones tend to be work, particularly in the material that grips the spring in the center.  Thus it can slip quite often.  2. This model nay has one arbor size.  That means if you work on smaller movements with smaller springs, you may bend the center out of shape or even break it.  In the case of wrist watches and smaller sprinted movements, it won’t fit at all.
you can buy new winders one arbor at a time and build your set to your needs.  They are a bit more expensive per arbor than a set, but if you don’t need a complete set, you save money and get the right tool.  I must admit to coveting Marks Bergeon set in his videos even though I will NEVER need all those sizes.
best of luck and do reach out with pocket watch questions and suggestions.  I love to compare experiences.
Link to post
Hello Rexxus.
Thank you for your message! In terms of pocket watches, what would you say is the most common mainspring size? Any rules of thumb you’re aware of?
Link to post
I could never get on with watch or P/watch winders. It is not bad practice. Just make sure you never take the spring out so it looks un-even, it should lay flat. Use finger cots to put the spring in.
Link to post
I'm afraid not.  The springs are by movement size and caliber.  You may find reference material to help you find interchangeable parts.  I do have a very significant stock of NOS pocket watch parts.  If you can tell me more I’d be happy to give you a spring or two to try.  I have thousands of NOS mainsprings for movements from American 18s to 21/0.  If that doesn’t make sense to you, post pics of what you have.  The face, the movement and the barrel with measurements of each.  Maybe we could narrow it down?
Do you have the old spring?
Link to post
I think the OP is just trying to decide if buying a MS winder and what are the common sizes he may encounter working on American pocket watches. Not fixing a watch at hand.
Link to post
Hiya,
Thank you for the offer!!! I don’t have a specific spring I’m working on now. I’ve been buying the supplies and equipment I need and have picked up a few pocket watches to take apart, clean, and put together. Some are missing parts. Once i start taking them apart I’ll definitely be posting pics and reaching out :)
  • Confused 1
Link to post
2 hours ago, praezis said:
If you intend to work on PWs only, you will surely need no winders for ladies WW. You could get a coarse idea of the needed winder sizes if you take half of the movement diameter minus 20%.
Frank
20% of the half? Or 20% of the whole movement measure?
ive never heard this guideline before.
Link to post
Makes sense. Barrel can't be bigger than half of mov.t dia, but (normally) is as large as possible. Minus 20% to clear.
Link to post
Do as you like, results are the same.
Call it Frank´s Rule :).
Seems likely as mentioned by jdm.
Frank
Link to post
Hello,
I just bought these K&D 123 mainspring winders (set of 3). I'm currently practicing on Chinese skeleton movements.
I also just finished the Level 2 course. So I'm curious, is it possible to use this on the 6498? I was told by the buyer that he has not tried it on the 6498 as it's a pocket watch movement. But what would happen if I use the biggest (11mm) winder? Will it damage the mainspring, or will it just not load in the winder entirely?
Thanks
Link to post
Yes.  You did.  I have a set of the K&D Winders and they're fine for vintage movements, generally not large enough for modern movements.  You can hand wind that MS back into the barrel.  It takes some practice, but it is doable.
RMD
Link to post
  • jdm changed the title to Mainspring Winders
  • jdm pinned this topic
