Mainspring winders
A new picture (sorry for the bad quality) to show this strange instrument.
Here you can see  that there is very little space between the hook and the barrel.
On the background there is a piece of mainspring 1,5 mm width.
It is not a mainspring or hairspring winder. Why the huge diameter of the arbor?
Has anybody an idee what you can wind/bent with is?
  • 4 weeks later...
I have found one make of winder does not fit all. I have three styles the Bergeron half set (because of cost) that I have added to as needed a cheap winder set I purchased from the USA + a K&D winder that fits the larger sizes including pocket watch sizes. However one issue that does happen is the shafts can be too fat or thin. To thin is OK because the inside coil can be closed a touch but if the shaft is to tight it can be a real issue because releasing the wound spring can really go belly up.
So my first reaction was the same as everybody else mainspring winder. The handle is interesting in that as pointed out you can only wind a really tiny mainspring with it. So a clue is the name of the company Eterna found in early automatic wristwatches. So as a guess the purpose of this tool is for winding in the slipping spring or 'bridle' Which on the early automatic watches was a separate spring. On the modern watches it's attached and you don't need a tool like this anymore.
John
  • 2 months later...
Spotted a boxed set of 10 Mainspring winders  on Ebay on Sunday night for a very reasonable price. Great news for me is that it turned up in the post on Tuesday morning which, considering the time of year, was exceptional as my expectation was that it wouldn't turn up until after Christmas maybe even the new year.
Spent a happy few hours last night cleaning the tarnish and slight surface rust from some of the winders and handle. To my untrained eye's, all looks pretty good with decent hooks on the arbour's.
Managed to wind a few springs  from my stash of scrap movements without  too much difficulty after watching Marks video on the subject again. Considering this was my first attempt, I was pretty happy with the results.
No manufactures name on the my winder's just stamped with Swiss. In design, the winders look very similar to the Bergeon  one's in Marks video.
There are a few gaps in the set though, I have 00,0,4,5,6,11,12,13,14,15. Not sure if this is  going to be sufficient for my needs  for now, or if I'll need to add a few more to make a more comprehensive set in the future.
With this in mind, if anyone has a set of Bergeon winders, I'd be very interested to know what the internal diameter of the handle is to see if it matches mine.
NAD
Thought that may be the case but was hoping otherwise. Will have to wait until I use them in earnest to find out if the winders I've got fit.
Handle is interchangeable between the winder bodies, is a good fit and not loose when in place. Can be removed once unlocked from the winder body easily enough.
Measures 12mm in diameter on the winder body where the handle fits which I'm hoping will be the same for the Bergeon ones that Cousins sell. That would make it easy to add to the set to make it more versatile.
  • 4 months later...
Hi everyone I've been learning a lot from the Youtube and this Forum, right now i'm confident enough to open and service a Rolex
and would like to ask about the Bergeon  Mainspring Winder set, in my country are available only the 2795 ETA-Set which contain 12 winder
or the Bergeon 2729-T which comes in single No.3-No.7 ( not sure) I mainly work on Rolex ref. 6694,1601,1603,16014,5500, etc
(cal.1220,1530,1570,3035,3135) not sure the set I mention above will fit all this Cal. , If not I may have to order online for 2795 (set of 17)
thank you for any answer !
Paul,From Thailand
I can't answer that question and hope someone that has experience with them can. But in my mind they should be good just by  looking at their price tag which is very Bergeon...All that said, I, mostly, am happy with whatever Bergeon tool I've managed to get...You need to realize that winders may fall into that category of old, main stream and "evolved/improved with time" sort of tools so I have no reason to believe they would not satisfy you. I just think there may be cheaper options out there with comparable quality (or better). I've also heard that they work well in Rolex.
Just my two cents!
Cheers,
Bob
Just my two cents!
Cheers,
Bob
Thanks for the quick reply Bob, anything is good for me if is work ! , saving money is a good thing ! haha
but I really need this thing (even not Bergeon), it will safe me a lot of time and risk of damage the spring ( which I broke a lot when I try to put in with my finger )
5 minutes ago, steven said:
If you are mainly working on Rolex watches, there are winders suitable for Rolex sold in material houses. I bought one for 3135 which is also suitable for some ETA movements.
I know from the seller that the 2795 ETA-Set > NO.7 are work for 3035/3135 also.
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
