Seiko 007 Advice
Is there a retaining ring missing on this watch?
59B4AAE1-9DB9-4790-869E-0036D9D44ED5_zps
The movement seems lose inside the case and the rotor sounds like it scrapes the back of the case it ticks and doesn't stop until I put the back on and you can see it drops in the case
9FA9A672-F211-436D-91F8-0581ECC70A46_zps
Does anyone know the part number that's mission or if there is a screw missing? Face done she keeps great time but not much use to me that way!
Looks like there should be a ring to me... But I've just looked at a similar automatic movement - there's no ring there and it has a similar perimeter gap to yours...
Edited by WillFly
Yes you do it's part no. 8720.2930, Cousins are due to get them back in stock from 2nd July.
Coincidentally, a friend of mine broke the mainspring on his Rolex last week. When he went to Cousins to get a replacement he also discovered that he has to wait until July before it's in stock. Perhaps they only order at particular times of the year.
I have had split deliveries from Cousins and they didn't charge extra delivery.
Indeed - with split deliveries they always send via the method you first chose. So if you chose RMSD they will ship the first package via RMSD (which costs the best part of £8) and the follow-up delivery also via RMSD but they eat the cost of delivery of the second parcel.
I received a back-ordered glass which cost £0.70 via RMSD a while back which amused me!
Well it arrived
2699683F-7B61-463F-AFCE-CAFE3D5ADC96_zps
this morning from cousins popped straight in and voila it's working again just need some spring bars and I will pop it on this mesh I got for £2.95!?!! How on earth can they make it at that price and what kind of mark up must some companies make on their bracelets!!
0A321060-5BBB-4BF7-A7DE-8C1660FC6F81_zps
Anyway I must have had the last one but this has been a successful week! I also picked up a bracelet for this cheepy which I think works well when compared to the rubber it was on
6F6F2369-7D0D-4C29-88DB-692EF56E6A75_zps
94B6BB16-8A52-4455-BA2F-73D6C0459805_zps
Put together it looks good, from the eBay description I wasn't sure what I was getting
'watch starts and runs for long spells then stops so maybe need a service or oiled , lovely condition , glass , bezel and dial , bezel turns freely does not click and crown screws down nice and tight , therefore spares or repairs'
I thought there might have been à bit of grit/dirt in the watch causing it to stop so chanced my arm and got it for £30 when it arrived it clearly ran well face down but the movement moved around, so thanks to this forum I found the correct retaining ring from cousins for £1.50 and a £2.95 mesh bracelet and voila a fully working classic seiko diver for under £40 to say i am chuffed is an understatement!!
193C6E40-E3B9-42E4-893A-5324B34D224C_zps
04C20179-44B9-48A4-9147-88367546E754_zps
I by chance found the previous 2 listings of this watch on eBay (same serial number and both times sold for under £35) this one won't be going anywhere for a while!!
