  • 1
mousekar
What's The Difference With Moebius 8000??
Question
Hello All!
New to the forum and relatively new to watch repair. I tried looking for the answer to my question before posting and haven't found anything as of yet, so if I missed it, I apologize.
I wanted to know a bit more about the Moebius 8000 watch oils. Specifically the 8000 and 8141. When I look at a lubrication chart, I see these listed along side the 9010 and D5. Are these viable alternatives? They tend to be more cost effective. Are the 9000's synthetic and the 8000's not?
Will the 8000's work for the slower pocket watches, but not higher beat rate watches?
Here is the chart I am referring to:
Thanks in advance for the knowledge! This forum is fantastic!
Share this post
Link to post
24 answers to this question
  • 0
For what it's worth, I chose the 8000 series in ignorance when I started out. They are cheaper, but the shelf life is only 2-3 years. Buy the smallest quantity you can... Whatever you choose, don't be drawn in by buying more to get a lower price, you will never use it before it goes out of date!
S
Share this post
Link to post
  • 0
StuartBaker104, I can get onboard with that. Just wasn't sure if that was the only real difference, or if the synthetics are better in other ways. Nobody that I've read ever brings them up when suggesting oils to purchase, so I wanted to see what the opinions were on the stuff. Guess I'm trying to figure out if it's still a quality oil, just with a much more limited shelf life.
I did read somewhere, that back in the day when pocket watches were king, that the expected time between services was about a year, and now it's more like 5-6. But if I'm servicing my own, then can I use these oils knowing I'll need to service them more often.
Then again, I've also read that every time you take them apart, there is always a chance that you take. Which I can DEFINITELY attest to.
Share this post
Link to post
  • 0
Question on watch oils, if they only have a shelf life of 2-3 years what is their service life in use?
You expect to get about 5 years from a service, if the oil only lasts for 2-3 years in a sealed container what chance in the environment of a watch movement.
Max
Share this post
Link to post
  • 0
Hey bob, I think I read somewhere else on here that you can use 9010 on the pallet jewels in a pinch. I think it may have been you, which is why I'm asking, but what are your thoughts with that?
Share this post
Link to post
  • 0
I think it is the first column?
Moebius is highly inconsistent and incomplete in their own application chart, that probably has not been updated in 30 years.
Their specialize pallet jewels oil is supposed 914 or 9145, about which it has been written:
9415 remains a grease until impact of the pallet, at which time it momentarily liquefies. This keeps lubricant where it belongs and away from the many parts of the escapement where it does not belong
Believe that if you wish.
Edited by jdm
Share this post
Link to post
  • 0
err yes,...I've said that before but if pressed I only do so on slow beat movements. If you don't have 914 at hand (or don't want to invest on it and make Swatch richer....mmmm, shame on you! ) that's the solution...you are still making Swatch rich!!! I know they are everywhere even in the oil, it is a nightmare!!
In any case, 9145 works well in all movements for that function low and high beat. So there you have it, now you know where your money will go!!!
      :D
Cheers,
Bob
Share this post
Link to post
  • 0
The chart in the first post confirms this. There was a time before 9145 existed and 8000 or 9010 was the recommendation. If it was ok when the watch was new, then why not now?
I used 8000 on pallet jewels before I bought some 9145.
S
Share this post
Link to post
  • 0
Thanks everyone. The watches that I'm currently working on are a Hamilton 917 and a Waltham Os trench watch. Like Bob said I'll have to save up for the 9145, as I just bought the D5 and Molykote DX. Sounds like I'll be ok for now with the 9010 on the pallet jewels for those, but 9145 will be the next purchase.
Also thanks for the clarification on the chart.
Share this post
Link to post
  • 0
I just sprung for some 9145 and now I have all the oil I will ever need; I think.
9010, 9415, 8013, 9104 (HP 1300), D5, KT22. About 250 bucks in oil. Hell, I'm in the oil business I guess
Share this post
Link to post
  • 0
I would have only chosen between HP1300 and D5 and bought only one of the two. They are equivalents being the HP much more expensive but with a longer shelf life and synthetic.
Share this post
Link to post
  • 0
After reading this, I may have chosen the wrong oils.  I use 8000 for the Escape Wheel, Balance, Gear train and pallet fork pivots.  I use 914 on the pallet jewels and 8030 on the winding mech and spring.  For the center wheel, I use D5.  Should I be using 9010 instead of the 8000?  Crap, I'm the idiot that bought three jars of it too.... :cold:  The movements I work on are always vintage and are typically low beat.
Edited by jeffc83
Share this post
Link to post
  • 0
Jeff,
8000 is fine, just don't oil the pallet pivots on movements below 12 ligne. Above 9 ligne you should use your D5 for the train wheels not 8000. See the table in the first post for confirmation of this.
941 came out after the table was produced, but was made for pallet jewels.
8030 is clock oil, do you mean 8300 for the winding mech and spring?
S
Share this post
Link to post
  • 0
Jeff,
S
Thanks VERY much for that advice my friend, I've been using 8000 on train wheels until now;)  Thanks again for the quick response!
Darn typo, yes, I meant 8300 for the mech and mainspring.  Should I be using 8200 or is 8300 acceptable?
EDIT:  If anyone is interested in 8000, I have PLENTY;)
Edited by jeffc83
Share this post
Link to post
  • 0
I might be interested in the 8000.  How much are you willing to let it go for?   I read somewhere that, if you were only going to use one oil for all pivots, 8000 was the way to go.  Amy truth to that?  Also, 8000 is a natural oil.  Should I be switching to a synthetic instead?  Total newbie here.
Share this post
Link to post
  • 0
Welcome!!!  I prefer the natural oil.  I'll look up what I paid for the 3 and divide it:)
Share this post
Link to post
  • 0
I paid just under 7 US dollars per vial.  I have no idea what this stuff would even cost to ship but wouldn't think It would be much...
I truly do appreciate the offer, but with shipping, that would be what I'm already paying, so I will have to pass on the oil.  But thanks for the offer, and for the advice.
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
    • Ok then that settles that. Yeah I thought I saw it titled Horolovar 400 day clock repair so it stands to reason that it's probably the most informative.
      I was also looking on one of my favorite sites on the net: clockworks.com I'm not sure if you're familiar with it but it has a wonderful clock repair kit with a comprehensive e-book with a repair guide for cuckoo clocks, anniversary clocks, spring driven and weight driven clock repair. Also with that you get an oiler with oil, cleaning solution, visor, level, brass brush, hand/gear puller and a mainspring letdown key all for $69. Seems like a great deal for all that and I'm fairly certain is not all Chinese crap either.
      I need to get a staking set and anvil, a better hammer, decent screwdrivers, (also unsure as to what the best ones for clock repair are) bushings and the necessary tools to do that work, all at a smaller price point.
      I don't have the funds to shell out atm for everything I want. Also I'm only in the hobby phase for now. I am, more and more coming to truly enjoy working on clocks and watches and am considering doing this for a source of income. When you can turn a hobby into a job it's a win-win.
      Sent from my Z956 using Tapatalk
    • Terwillger's book is the one I had. That is the bible of anniversary clocks.
    • I'm not familiar with Rabuska's book so had to look it up. But putting it simply Terwillger's book is published by Horolovar which is the company that also makes the replacement suspension springs and mainsprings for anniversary clocks, it is considered 'The bible' for Anniversary clocks. It is also 237 pages compared to 98 pages for Rabuska's. I'm not saying Rabuska's book isn't good as I don't know as I've not read it, but if I was only going to get one book I would get the Horolovar book as it gives setup suspension spring drawings for pretty much all anniversary clocks.
    • Thanks very much OH! I'll be sure to ask how old it is before viewing, and check what you mentioned when I see it.
    • Looks complete. You will need a motor to run it. Check the lathe bed and make sure it is smooth with no marks in it. Ask what type of work has been undertaken. how old is it? Make sure the collets are in good shape and not strained, out of shape collets are no good.  A fair price I would say.
