Seiko Sportsmatic 7625-8293
Picked this up recently for a snip from an excellent fleabayer in Japan:
A fairly clean item from August 1968 with a good dial. Being a bit of a fan of Sportsmatics, I haven't come across this particular model before & wrongly thought at first that it had a cyclops crystal retro fitted. Further research showed this to be the original configuration, however the crystal was in fairly poor nick & appeared to have been polished a few times in the past. After some more detective work the part number was obtained & amazingly Cousins had one in stock:
So far so good, although the rotor sounds a little rough (not uncommon on these). Lets see whats inside:
Bit grubby with a scraping rotor, but the bearings seem OK, so the rotor gets bent upwards slightly - don't frown, it's what Seiko recommends!
Out of the case, dial & hands off, strip down the dial side. Note the broken setting lever spring, I have a donor movement from a previous project and will replace this:
post-80-0-88468600-1457205582_thumb.jpgpost-80-0-61565600-1457205587_thumb.jpgpost-80-0-06895900-1457205592_thumb.jpgpost-80-0-45987400-1457205596_thumb.jpg
Turn over & rotor off:
Remove the winding gear:
Strip down the above, a bit of wear on the magic lever but appears to work fine, clean lube & reassemble:
Onto the main stripdown:
post-80-0-85418800-1457206066_thumb.jpgpost-80-0-20739100-1457206071_thumb.jpgpost-80-0-53386600-1457206075_thumb.jpgpost-80-0-93160000-1457206079_thumb.jpgpost-80-0-37013400-1457206084_thumb.jpg
All in bits & cleaned:
Lower Diashock dismantled, cleaned then reassembled:
Then it all goes back together:
post-80-0-65098900-1457206113_thumb.jpgpost-80-0-17995900-1457206118_thumb.jpgpost-80-0-05419300-1457206122_thumb.jpgpost-80-0-63800500-1457206129_thumb.jpgpost-80-0-56959400-1457206133_thumb.jpgpost-80-0-99103100-1457206175_thumb.jpg
On to the dial side, setting lever spring replaced:
post-80-0-17426700-1457206229_thumb.jpgpost-80-0-58108000-1457206234_thumb.jpgpost-80-0-22170400-1457206240_thumb.jpgpost-80-0-15017400-1457210051_thumb.jpgpost-80-0-18601500-1457206583_thumb.jpgpost-80-0-08179900-1457206587_thumb.jpg
Into the case, reattach winding gear, rotor  & caseback on:
post-80-0-32648300-1457206591_thumb.jpgpost-80-0-09512300-1457206596_thumb.jpgpost-80-0-19572200-1457206600_thumb.jpgpost-80-0-03835900-1457206604_thumb.jpg
The original crystal was used before the previous step to protect the hands, this is now removed the dial is given a final clean before putting the new crystal in place, which pushes on under finger pressure. The crystal is held firm by the bezel, which is a problem to fit as all of my dies are shallow & bevelled, unable to push the bezel down, so 2 pieces of 40mm waste water pipe are cut to suitable length, one piece is then fitted onto a stepped flat die, the other has a section removed and placed inside the first:
Works a treat. Finally, with a new tan alligator strap fitted:
It looks like the crown has been replaced with the wrong one in the dim & distant. Hopefully this will be rectified in due course.
  • Like 5
Thanks for the kind comments all.
Jdm - timegrapher reading as requested:
Taken dial down, there is a little variance on other positions & I will give it another look in a week or so once its bedded in. The original readings before service were: Rate +/-13 seconds, Amp 194, BE 1.2
Brilliant!  And so nicely photographed as well.  Oh how I wish my hands weren't so shaky as well as my confidence.  Looking at the pile of parts I would have no idea of the reassembly order.  This is where your craft and intelligence comes into play.  Bravo!
excellent tutorial! well done and easy to follow. that sportsmatic is a beauty. that is a great classic look with those beautiful dauphine hands. and these sportsmatics seem to have much larger indices than other seikos. maybe i'm imagining that  - but it seems so.
i've got three of them - and i think one more around here somewhere. mine are 6619's from 1964, 1967 and one i can't date. they're a nice dress watch and just the right size.
attachicon.gif13.jpgattachicon.gif14.jpgattachicon.gif15.jpgattachicon.gif16.jpgattachicon.gif17.jpg
attachicon.gif21.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif22.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif23.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif24.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif25.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif26.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 27.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif28.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif29.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif30.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif31.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif32.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 33.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif34.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif35.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif36.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 38.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 39.jpg
What a great job
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
