Seiko Sportsmatic 7625-8293
Picked this up recently for a snip from an excellent fleabayer in Japan:
A fairly clean item from August 1968 with a good dial. Being a bit of a fan of Sportsmatics, I haven't come across this particular model before & wrongly thought at first that it had a cyclops crystal retro fitted. Further research showed this to be the original configuration, however the crystal was in fairly poor nick & appeared to have been polished a few times in the past. After some more detective work the part number was obtained & amazingly Cousins had one in stock:
So far so good, although the rotor sounds a little rough (not uncommon on these). Lets see whats inside:
Bit grubby with a scraping rotor, but the bearings seem OK, so the rotor gets bent upwards slightly - don't frown, it's what Seiko recommends!
Out of the case, dial & hands off, strip down the dial side. Note the broken setting lever spring, I have a donor movement from a previous project and will replace this:
post-80-0-88468600-1457205582_thumb.jpgpost-80-0-61565600-1457205587_thumb.jpgpost-80-0-06895900-1457205592_thumb.jpgpost-80-0-45987400-1457205596_thumb.jpg
Turn over & rotor off:
Remove the winding gear:
Strip down the above, a bit of wear on the magic lever but appears to work fine, clean lube & reassemble:
Onto the main stripdown:
post-80-0-85418800-1457206066_thumb.jpgpost-80-0-20739100-1457206071_thumb.jpgpost-80-0-53386600-1457206075_thumb.jpgpost-80-0-93160000-1457206079_thumb.jpgpost-80-0-37013400-1457206084_thumb.jpg
All in bits & cleaned:
Lower Diashock dismantled, cleaned then reassembled:
Then it all goes back together:
post-80-0-65098900-1457206113_thumb.jpgpost-80-0-17995900-1457206118_thumb.jpgpost-80-0-05419300-1457206122_thumb.jpgpost-80-0-63800500-1457206129_thumb.jpgpost-80-0-56959400-1457206133_thumb.jpgpost-80-0-99103100-1457206175_thumb.jpg
On to the dial side, setting lever spring replaced:
post-80-0-17426700-1457206229_thumb.jpgpost-80-0-58108000-1457206234_thumb.jpgpost-80-0-22170400-1457206240_thumb.jpgpost-80-0-15017400-1457210051_thumb.jpgpost-80-0-18601500-1457206583_thumb.jpgpost-80-0-08179900-1457206587_thumb.jpg
Into the case, reattach winding gear, rotor  & caseback on:
post-80-0-32648300-1457206591_thumb.jpgpost-80-0-09512300-1457206596_thumb.jpgpost-80-0-19572200-1457206600_thumb.jpgpost-80-0-03835900-1457206604_thumb.jpg
The original crystal was used before the previous step to protect the hands, this is now removed the dial is given a final clean before putting the new crystal in place, which pushes on under finger pressure. The crystal is held firm by the bezel, which is a problem to fit as all of my dies are shallow & bevelled, unable to push the bezel down, so 2 pieces of 40mm waste water pipe are cut to suitable length, one piece is then fitted onto a stepped flat die, the other has a section removed and placed inside the first:
Works a treat. Finally, with a new tan alligator strap fitted:
It looks like the crown has been replaced with the wrong one in the dim & distant. Hopefully this will be rectified in due course.
  • Like 5
Thanks for the kind comments all.
Jdm - timegrapher reading as requested:
Taken dial down, there is a little variance on other positions & I will give it another look in a week or so once its bedded in. The original readings before service were: Rate +/-13 seconds, Amp 194, BE 1.2
Brilliant!  And so nicely photographed as well.  Oh how I wish my hands weren't so shaky as well as my confidence.  Looking at the pile of parts I would have no idea of the reassembly order.  This is where your craft and intelligence comes into play.  Bravo!
excellent tutorial! well done and easy to follow. that sportsmatic is a beauty. that is a great classic look with those beautiful dauphine hands. and these sportsmatics seem to have much larger indices than other seikos. maybe i'm imagining that  - but it seems so.
i've got three of them - and i think one more around here somewhere. mine are 6619's from 1964, 1967 and one i can't date. they're a nice dress watch and just the right size.
attachicon.gif13.jpgattachicon.gif14.jpgattachicon.gif15.jpgattachicon.gif16.jpgattachicon.gif17.jpg
attachicon.gif21.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif22.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif23.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif24.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif25.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif26.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 27.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif28.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif29.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif30.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif31.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif32.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 33.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif34.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif35.jpghttp://www.watchrepairtalk.com/public/style_images/master/attachicon.gif36.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 38.jpg
http://www.watchrepairtalk.com/public/style_images/master/attachicon.gif 39.jpg
What a great job
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
