Eta 2824-2 Stem Release Pusher Stuck
Flo
Hi everyone,
I'm new to this forum, and I'm looking for help!
I'm facing this problem : while fixing the dislodged keyless works on my ETA 2824-2 (seems like a classic issue, from what I've read), I pushed the stem release pusher too far and it wouldn't come up again, it is stuck under, probably dislodged...
Do you guys have an idea on how to fix that ?
Thank you in advance !
All right, thank you Gingerr6.
The piece that I need to access is the setting lever (443/1), right ?
I access it from the front of the movement, by taking off the screw for combined setting lever jumper (5445), then the combined setting lever jumper (445/2), and then the yoke (435), is that correct ?
IMHO, it is best to, once you remove part 5445, check what you find...
you may have to simply reset the whole thing but if there is something broken or bent then you may need to replace or fix accordingly.
Cheers,
Bob
PS. Welcome aboard!
If you dont want to take the dial side off, didnt mark have a clever way of accessing the key less works without dial disassembly somewhere in one of his videos?
Edited by jnash
I believe you're right I remember seeing it myself Mark removed the barrel bridge and got to it from there if we are talking about the same video
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
