Crystal Polishing?
mcass
I am VERY new to watch repair. I have an M9 Bulova Oceanographer that had some very serious scratches and gouges in the crystal. At the suggestion of a friend, I used Flitz Metal Polish on it. Simply rubbing it over the crystal with my index finger in circular motions for literally about 8-10 hours across a two week time frame. The crystal is now gorgeous with no signs of scratches or other imperfections.
With my success doing this, I bought a 90's Seiko at a thrift shop for a couple of bucks that had some very serious scratches in it (not near as bad as the Bulova). I have tried the same thing on the Seiko for an hour or so and don't think it is doing a thing. Are crystals made of different materials? Can a Seiko crystal be polished?
Many vintage "crystals" are actually a plastic polymer resin or plexiglass, Omega has a plastic crystal material named Hesalite.
These can be polished quite easily with great results by simply using a very fine abrasive like Brasso.
Mineral crystals are the next step up and are much harder than plastic but can still be scratched. One advantage is that the aren't as brittle as sapphire crystals. Being softer than sapphire they can be polished more easily, but not as easily as plastic.
Sapphire crystals are hardest of the three and are hard to scratch (but not impossible) and are hard to polish without proper abrasives and tools.
Hello Mcass & JiminOz;
I'm currently facing the same problem / question. I bought some diamond paste, different grit sizes from #600 down to #10.000 and attempted with a Proxxon, similar to a Dremel, and small felt-discs to polish a sapphire crystal. Started of with #1000, but that didn't seem to bring anything. With grit #600, slow progress is made, but the crystal gets quickly very hot. Obviously I try to spread the heat evenly over the crystal to avoid great stresses, and allow cooling periods, but progress is slow.
Edited by Endeavor
Unless your crystal is unobtainable then I'd just suggest a new crystal (even generic crystals may be suitable).
Far easier, and the risk with using buffing discs is dishing or ending up with an uneven surface. Ideally you would grind the crystal on a super flat plate (unless it was domed).
Very true that the sapphire crystal may/will not become flat. I started off on a flat mineral glass plate, manually, and unlike as "shown" on some YouTube video's, I wasn't getting anywhere.....that is to say, it was the mineral glass plate which got grinded :(
My first learning "casualty" sapphire crystal is from a cheap quartz watch, a watch not worth a new crystal.
Seems, to get a perfect job, you need one of those disc they use to polish diamonds? ($$$?)
To summarize; I had no real suc6 jet.........
Edited by Endeavor
I've experimented by making a paste of cerium oxide, a tiny drop of cooking oil and bicarb powder.  I also used a Dremel with a polishing disk.  First I ran the paste over the crystal, then used the Dremel for about thirty seconds.  Then you wait a minute or so for the crystal to cool and then repeat.  It takes some patience but it does make a difference on glass crystals.
Edited by stroppy
Where can you get Seiko crystals and are they difficult to change out?
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
