Crystal Polishing?
mcass
I am VERY new to watch repair. I have an M9 Bulova Oceanographer that had some very serious scratches and gouges in the crystal. At the suggestion of a friend, I used Flitz Metal Polish on it. Simply rubbing it over the crystal with my index finger in circular motions for literally about 8-10 hours across a two week time frame. The crystal is now gorgeous with no signs of scratches or other imperfections.
With my success doing this, I bought a 90's Seiko at a thrift shop for a couple of bucks that had some very serious scratches in it (not near as bad as the Bulova). I have tried the same thing on the Seiko for an hour or so and don't think it is doing a thing. Are crystals made of different materials? Can a Seiko crystal be polished?
Many vintage "crystals" are actually a plastic polymer resin or plexiglass, Omega has a plastic crystal material named Hesalite.
These can be polished quite easily with great results by simply using a very fine abrasive like Brasso.
Mineral crystals are the next step up and are much harder than plastic but can still be scratched. One advantage is that the aren't as brittle as sapphire crystals. Being softer than sapphire they can be polished more easily, but not as easily as plastic.
Sapphire crystals are hardest of the three and are hard to scratch (but not impossible) and are hard to polish without proper abrasives and tools.
Hello Mcass & JiminOz;
I'm currently facing the same problem / question. I bought some diamond paste, different grit sizes from #600 down to #10.000 and attempted with a Proxxon, similar to a Dremel, and small felt-discs to polish a sapphire crystal. Started of with #1000, but that didn't seem to bring anything. With grit #600, slow progress is made, but the crystal gets quickly very hot. Obviously I try to spread the heat evenly over the crystal to avoid great stresses, and allow cooling periods, but progress is slow.
Edited by Endeavor
Unless your crystal is unobtainable then I'd just suggest a new crystal (even generic crystals may be suitable).
Far easier, and the risk with using buffing discs is dishing or ending up with an uneven surface. Ideally you would grind the crystal on a super flat plate (unless it was domed).
Very true that the sapphire crystal may/will not become flat. I started off on a flat mineral glass plate, manually, and unlike as "shown" on some YouTube video's, I wasn't getting anywhere.....that is to say, it was the mineral glass plate which got grinded :(
My first learning "casualty" sapphire crystal is from a cheap quartz watch, a watch not worth a new crystal.
Seems, to get a perfect job, you need one of those disc they use to polish diamonds? ($$$?)
To summarize; I had no real suc6 jet.........
Edited by Endeavor
I've experimented by making a paste of cerium oxide, a tiny drop of cooking oil and bicarb powder.  I also used a Dremel with a polishing disk.  First I ran the paste over the crystal, then used the Dremel for about thirty seconds.  Then you wait a minute or so for the crystal to cool and then repeat.  It takes some patience but it does make a difference on glass crystals.
Edited by stroppy
Where can you get Seiko crystals and are they difficult to change out?
    • Thanks, This watch was in a box of old scrape units that a friend gave me. They used to be his late father's who was a watchmaker before the war and then continued later in life. I picked this one out as it looked like it had potential, and I liked the dial, it's been a bit of a learning curve for a beginner but I was determined to get it going. Now I'm on the final lap it feels good. I'm just wondering whether to invest in a decent set of hand placement tools or stick with the cheap Chinese red thing I have, decisions decision 😆
    • An update, for everyone who contributed advice, and for those who come after with a similar problem. Based on the answers received, I decided to work on the face of the hammer first. I used a square degussit stone to guarantee a vertical surface to work against, and ground the face back until it was square across 90% of the depth. I was conscious of the risk of removing too much material.* After I'd got the shape how I wanted it, I polished the surface with lapping film. To cut a long story short, it did the trick and the hammer hasn't slipped off the cam since. Of course, that wasn't the end of my problems. Have a look at this video and tell me what you think is wrong. https://youtu.be/sgAUMIPaw98 The first four attempts show (0 to 34 sec.) the chrono seconds hand jumping forwards, the next two attempts (35 to 47 sec.) seem "normal", then on the seventh attempt (48 to 54 sec.) the seconds hand jumps to 5 sec. and the minute counter jumps to 1. The rest of the video just shows repeats of these three variants. I solved it by rotating the minute counter finger on the chronograph (seconds) runner relative to the cam.  I'd be interested to hear your opinions on that. It seemed to be the right thing to do, but maybe I've introduced another problem I'm not aware of. * What is the correct relationship between the two hammers and cams, by the way? Should both hammers strike the cams exactly at the same time, or is it correct for the minute counter hammer to be a bit behind the seconds hammer? In this picture, I removed the adjusting screw at 1, and the hammers are contacting the cams simultaneously at 3 and 4. I had to turn the screw down tight to achieve this condition after stoning the seconds hammer and replacing the bridge.
    • It was easy enough to pop off. Once I had the cannon pinion hanging on the blades of the stump, I got my #2 tweezers on the gear attached to the staff and levered it down. That way none of the force was on the brass wheel itself.   I reinstalled it and the bridge, and it looks like a small but reasonable amount of end shake. It also spins easily with a blower. It stops quickly, but I think that's due to the large shoulder and about what I'd expect from this wheel.
    • Oh, right. For some reason I was picturing a monocoque case in my head. Good looking watch!
    • Well said Ross. My reason for the thread, i like many of us dont want to lose the forum, such a well knitted group of individuals i feel. But things can happen out of anyone's control. Would be nice to have something in place just in case, if anyone has any ideas please speak up.
