Cheap Pegwood
SSTEEL
Hi
I was trying to find the home made tools thread to post this but I couldn't.
Anyway, I have been using Souvlaki skewers for pegwood. I love the sharp point! Try as I might I can't get a pegwood anywhere near that sharp.
Someone mentioned chopsticks but I find them a little thick for my purposes.
Dave
Do'nt do it - you will end up making new tools for/with you lathe all the time!   ;)
Thank you!
I must admitt that I usually end up using my small mill when refinishing cases - easy to adjust the angle of the disc, the hight e.t.c. e.t.c. and standard collets makes life easy! :)
A badly beat up Speedy MKII case lapped in the machine above using a 305mm disk with 240 grit paper.
Amazing job.
  • 2 years later...
Hello, I am new to this forum, hope to be joining the right thread.
While watching Mark's course, I ordered my first tools and the clone movement. But it takes an astonishing 50 days for them to arrive... :(
So to gain time, and procrastinate a bit from my real work (lute making) I started making a few basic tools.  But finding the right profiles to copy is challenging. So many angles for the hand levers... I chose 30 degrees, and repurposed some useless screwdrivers I had around.
Next the oil containers..which size? Is it critical to have small concave pools? Or they can be 8-10 mm wide? I used some camera lenses, with concave surfaces. Cannot imagine something closer to the agathe or cristal used on the professional ones. For the caps, I used more lenses. The container seems tight enough to hold the dust outside, while good enough to concentrate the puddle of oil on the center. One interesting effect I found is that with the cap (the second lenses) I can see magnified how contaminated my oil already is...
Then the oil needles.. The shape is easy to copy, once you find close images of fine oilers, but what kind of surface transports oil best? Shiny or matte? ( when cleaning the dippers, it seems that a shiny surface is best for assuring nothing remains on the tool..)
While Ebay still drag on indefinitely on the delivery of my tools, I finished the first part of Mark's course. I will not crowd the thread of the course with another review, but it was great! The pace is good for non native speakers, and the strategic choice of going for the bare minimum of tools make the endeavour  more realistic for people like me.
 I noticed that in the thread of bronze tweezers nobody questioned that bergeon and others (cousin's website) advertise their tweezers as brass. So, Brass or Bronze? I was about to fit brass tips to a really shit pair of tweezers I have. But in doubt, I chose to make them in boxwood...
I got a laser cutter that is now gathering dust. Does not really help me in lute making. But if anybody fancy designing a perspex tweezer holder, I would be happy to cut and post it. It cost nothing to make something like the model you have been discussing...Send me real pegwood in exchange... I refuse to buy it, but never saw the real thing.. :)
For the tweezers, I have both brass and bronze. I've settled on the bronze tweezers as my main pair,  as they are slightly harder that the brass. With the brass, I had problems keeping the tips in good shape. The bronze is still soft enough that I don't worry about scratching parts, and less springy than my steel ones so I get fewer parts pinging off into the ether.
I think your boxwood tweezers will do just fine for a start. As far as pegwood is concerned, it is just round sticks of (i believe) boxwood, about the diameter of a toothpick.
Have Fun!
@marcoskaiser you're REALLY good at what you do !!! RESPECT
Are you a professional luthier ?
Envoyé de mon Moto G (5) Plus en utilisant Tapatalk
Thanks manodeoro. Yes, that’s my profession. Guess most people here have some kind of mechanics background...
I was a band teacher for years and it was always necessary to do smaller fixes on band instruments; saxophones were the most prone to small dings causing problems with pad seating.
At seventy, I still teach a small community band with the same instrument problems.
During the other part of my life I was a concert piano technician and I also did complete overhauls to many different makes of piano. So, does that make me a kind of luthier?
You're welcome, and you really deserve congrats.
May I ask which sort of material you can cut with your laser cutter ?
6 hours ago, marcoskaiser said:
Only perspex, up to 10mm, and thin sheets of wood. A4 size
Too bad ... I hoped you could cut and/or engrave copper plates to make custom dials.
So I'll have to keep on working on my project of a rotating stand for dial engraving
  • 1 year later...
On 10/5/2015 at 11:36 AM, Geo said:
Here's a few.
I made this today for tightening the nut when replaing a rotor bearing on an Omega 1120.
Pair of levers (only one shown) great for hands and especialy snap case backs.
Balance tack.
Minute hand puller for an Atmos clock.
Movement holder for Atmos clock.
Took your example and made me a balance tack as well. With an extra hole for a k&d tool that was hanging around without a base.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
