Cheap Pegwood
SSTEEL
Hi guys,
Awesome link, the guy sells about everything. Looking for an appealing watch display I tried to buy this:
but he said he only sold the dress so I declined. :)
More seriously, I didn't find the circular pen holder. Was that something he provided out of ebay?
Cheers,
Bob
added some grommets to hold the items better
can be fitted top or bottom rail as suits the configuration of tweezers
you can even house irregular shapes
the mod to rotating stand for screwdrivers
l am intending to shorten the centre stem
Really nice stand you built . But those grommet where very expensive . £103 only for the grommets?
I like these mods., great idea. What I'd like you to do now () is come up with a screwdriver/tweezer stand that lies flat and holds them in place whilst doing so. I like to completely clear my working area when I've finished, and screwdriver carousels don't lie down flat in drawers unfortunately.
Stephen
Stephen
Can l be your own personal designer? please please Edited by Roamerofold
Well, a few more folks are like me, a cold wet afternoon and a lump of teflon and Colin has a new oiler holder. Just one of the many little things that plant the seed for others to follow.
Encouraged by the success of re-purposing my old Indian screwdriver stand to an oiler holder (http://www.watchrepairtalk.com/topic/3138-i-needed-a-stand-for-my-oilers/) and knowing I had another one in the junk box somewhere, I decided to see what I could use it for so I rustled it up.
I had made a quick and dirty holder for some bench tools from the foot of an old sofa that had gone to the charity shop, wasn't pretty but did the job.
post-1141-0-71594500-1448090561_thumb.jp
Using the same method, I popped the stand apart, chucked it in the lathe and marked the diameter and index marks using the index wheel on the lathe to produce six points.
Then to the drill press for pilot holes and final holes to suit the tools. Back together and I'm happy with it.
post-1141-0-35403400-1448090741_thumb.jp
And with the tools. They are a pair of hand lifters, a brass stabby thing I made from a clock chime, a steel stabby thing I made from a cheap screwdriver, and at the back, two Indian screwdrivers modified by removing the swivel heads and shaping the bladed into little flats, one with a blob of Rodico which was my go to jewel lifter until I got a proper one.
post-1141-0-02329000-1448090962_thumb.jp
This forum and the posts of the members is great for galvanising one into motion isn't it :-)
Edited by JimInOz
  • Like 5
I finally got the time this week to make a couple of tools I've been needing.
A tool for removing pendant tubed when refinishing cases.
A oiler that can be held like a pen for ultimate control. Made from 6mm anodized aluminium rod and a reshaped sewing needle.
Handremovers made from 5mm stainless rod
  • Like 6
Beautiful work RC nice.
I wouldn't say i was a tool maker but when i have some scrap material around i make some use of it :)
Pictured below, a couple of staff hammers ( for choice of better word ) i use these when replacing staffs and knocking out old ones, the smaller hammer for wrist and larger for pocket watches. The hammers have other uses too of course, both have stainless steel handles and brass heads which give just the right amount of weight, they ain't pretty but they work a charm.
There's a very rough looking aluminium lug pin removal tool made from a short scrap of stock, bang some holes and threads in the end and add some hardened steel tips tada.
A small screw driver i used for general stuff, i made this again out of scrap bits i bought in a joblot. Last picture is a small stand i made from scrap aluminium, just messing around with scrap and turned into a tweezer stand for now ha ha. The stand is quite sturdy and weighted despite being alu.
I do make higher quality tools when i have time but these are all i have that were all made purely from scrap. :)
When i do next make a set of screwdrivers i will be sure to share here :)
I just found one hidden away that i did, i really must finish the set but here's the 1.20mm. All stainless steel , 3mm grub retainer screw for holding blade in tight, and the knurled head is interchangable with others that i have lying around somewhere. Simple but effective :) I have drawings and plans for so many things but i rarely get time to make them currently, but since i found it i figured id share :)
    • I would harden and temper (to a light blue). It's so easy to do and only takes a couple of minutes. A search on ebay UK for "spring steel strip cs" finds plenty available in small quantites and thicknesses from 0.1mm up.  But the question is ( @nickelsilver) which "CS" number is best for watch parts ?  Also, from one of the ads : "CARBON SPRING STEEL. SIZE IS METRIC 15.00mm X 0.10mm X 304 MM  CS100 FINISH BRIGHT . HARDENED AND TEMPERD TO 480-530VPN" I've no idea about 480-530VPN. Does that mean it needs annealing before working?
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
