Cheap Pegwood
SSTEEL
As everyone know, some tools can be somewhat overpriced for what they are, take the Bergeon dial working platform for example.
21941361401_e28ff56732_b.jpgBergeon_7053_ by Micky Aldridge, on Flickr
BERGEON do sell some great tools of high quality, but the prices are crazy at times, the above dial platform retails at €189 euros.
I decided there is no way I would pay that much, and then started looking at how I could make my own, it couldn't be too difficult, right?
Here's what I came up with, not pretty, but it works, its a hockey puck, and I drilled lots of small diameter holes in the one side.
Hockey puck costs €3 euros delivered.
Started life like this.
11884909973_804a1ee154.jpgHockey Puck by Micky Aldridge, on Flickr
9721568379_5c1289802a_k.jpgMy Bergeon Alternative watch dial platform project by Micky Aldridge, on Flickr
After some drilling..
21310617573_87a87f19fd_k.jpgUntitled by Micky Aldridge, on Flickr
And here's another tool I made for a special case back screw design.
14503871614_9f33eed0c8_k.jpgUntitled by Micky Aldridge, on Flickr
Other thing I use, instead of Bergeon dial protectors when removing hands, I use a clean ziplock bag..
Oh, and a bonus item I made is this microphone dust cover.
21645633756_a6cceb3182_k.jpgUntitled by Micky Aldridge, on Flickr
Lets see what tools you have made to make your watchmaking more enjoyable without breaking the bank. :)
Edited by SSTEEL
  • Like 5
Here's a few.
I made this today for tightening the nut when replaing a rotor bearing on an Omega 1120.
Pair of levers (only one shown) great for hands and especialy snap case backs.
Balance tack.
Minute hand puller for an Atmos clock.
Movement holder for Atmos clock.
  • Like 7
Here's a few.
Balance tack.
Balance tack looks great .Tell us/me more?  Want to do one for myself . What material did u use?  Diameter of puck?
Here are some of my "tools"
Small tiltable table for one of my lathes
larger tiltable table for lapping
Lappingmachine for cases
Simple chuck
"Adapters" for case opener 5700 to open Speedmaster MKII cases, Heuers etc
Stand for oilers, anodized aluminium
Demagitizer
....and much more - I almost like making tools/machines more than refinishing watches!  :D
  • Like 5
Superb set up there for lapping and case refinishing, love it.  Thanks for sharing, I so cannot wait until I get my own lathe :)
Do'nt do it - you will end up making new tools for/with you lathe all the time!   ;)
Some good stuff there RCD, and a warm welcome to the forum. Your case refinishing kit reminds me that I still have an Omega Chronostop case that I must get around to finishing.
Thank you!
I must admitt that I usually end up using my small mill when refinishing cases - easy to adjust the angle of the disc, the hight e.t.c. e.t.c. and standard collets makes life easy! :)
A badly beat up Speedy MKII case lapped in the machine above using a 305mm disk with 240 grit paper.
Thank you!
You have some fantastic tools there your workshop must be of some size. Unfortunately my workshop is a converted small bedroom so such tools are just not possible. Maybe when I get that Lotto up !!!
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
