Hi djmcd,
I use lighter fluid and a soft brush to clean the parts, and then 2 quick rinses in 99% alcohol, then air dry on a paper towel (the alcohol evaporates really quickly, leaving no residue behind). If needed, I soak the parts in lighter fluid for some time, but never in the alcohol (it will dissolve the shellac used on some parts).
I need to get an ultrasonic cleaner too...
Hi,
New to this but hoping to get some good feedback and tips regarding the cleaning (service) of the  ETA 955 series.
I don't have the special cleaning machines and have to rely on an ultrasonic tank. What do watch technicians use in terms of cleaning fluid these days? I've seen a brand by L & R and was wandering if they are any good?
Thanks for your replies.
Hiren.
Why do you feel the need to clean it? Very rare for these to need it & if you do remove the circuit & Coil. These movements aren't that expensive to replace which is sometimes a better alternative than cleaning £ for £. whats the problem with the watch?
Hi,
Hiren.
I agree with Lee - it's more cost effective to replace the movement. However, if you are doing it for fun/challenge/practice then you should be fine using lighter fluid as a degreaser to clean the top and bottom plate, and the wheels. The stepping motor (magnet) can be cleaned in rodico.
Out of interest, as a 'clockie' , I have an ultrasonic cleaner like Hiren. How effective are they compared to proper watch cleaners? I've used it (with Elma chrono clean 1:20), and things come out pretty clean, but I've no idea if a proper watch cleaner would be any more effective...
I agree with the changing of a movement outright. However as a watch tech, I'm forced to repair small parts (circuit, wheels, levers etc..). I'm doing batch servicing for swiss quartz brands so constantly busy. Would be a dream to streamline my cleaning services let alone replace a movement! Sadly the big boys don't like replacing movements as, believe it or not, it's not cost effective for them.
As quoted above with the technique of brushing lighter fluid/benzene, this is what I have been doing and it's working pretty well so far. I was using isopropryl alcohol which worked equally as well.
I think the long and short of it is that there is no real way to sprint through this with an ultrasonic tank. And dare I say it... It's not **BLEEP** worth it... Especially for the money!  :growl:
For quartz watches I would stick to what you are doing. Be careful with benzene and Isopropyl Alcohol as they are really quite toxic. Lighter fluid is bad enough ;) make sure your workshop is well ventilated and try not to breath too much of it. Your health is more important than getting a watch movement running!
  • 2 months later...
Hi Chaps,
I have for many years used a water based cleaner (from M&P) in my ultra sonic cleaner. However I recently changed the cleaner to Elma WF pro + Elma rinse.
I have been really pleased with the cleaning but the fumes I find very overpowering also a bigger concern is the wife has started to complain. Has anyone had that same issue & if so what solutions have you found. I have been trying the purchase a dedicated watch cleaning machine such as the L&R ULTASONIC VARI-MATIC or an Elma but unfortunately I keep getting out bid on flee bay.  I don,t know whether these machine control the fumes better or if other cleaners such as L&R have fewer issues with the fumes.
I might have to move the cleaning side of the operation to my garage but hoping to find another way. :thumbsd:
Edited by clockboy
I can say that the l&r does not dissipate the fumes. Obviously The fumes are worse during the heating/drying stage.
It's best to operate in a well ventilated area.
I used to work in a department store and we used to keep the machine in a cupboard in order to keep the floor manager happy. It helped.
Thanks, does the L&R have less fumes than the Elma.
Even as I poured from the bottle to the cleaner is was very strong & smelly and as my workshop is a converted bedroom in my house er indoors is not happy. So I need to find a way around this, perhaps rig up an extractor fan.
I used to use solvent-based paints for spraying small items with an airbrush, many years ago, also in a fairly confined area. I rigged up a small fume cupboard - essentially a plywood box with a cloth front to it and an extractor fan behind it. The fan extracted the fumes into a cloth and rubber hose contraption and out of the window. A little clumsy, but it did get rid of fumes and was less hazardous to health.
As a young man I worked for a spell on a mobile library. In quiet periods we used to clean off the stickiness on the plastic covers of books with - guess what - carbon tetrachloride! Unbelievably lethal. My colleague, one cold day, was doing it with the bus door closed, and nearly collapsed from the fumes. Luckily I came back from lunch and got her out. Modern H&S would never have allowed that to be used - but it was early 1960s.
Willfly,
Similar story I was an apprenticed served letterpress printer followed a by a 2 year litho training scheme. During the early days as an letterpress printer we used to use a chemical called "ink stripper" without gloves this stuff would strip paint. In my litho days another chemical was used the revive printing blankets called MEK again lethal stuff and some of the guys used to use it without gloves. If you used it a lot it could make you very light headed. No H&S them days either.
I think I will try some sort of extraction fan rigged up to a tumble dryer extraction pipe but will waited to see if I can purchase a proper watch cleaning machine. In the mean time it will be the garage for me.
We used to use carbon tetraclouride as a degreaser when cleaning watches years ago until the chemist stopped supplying us. I currently use MEK as an accelerant for my micro flame soldering machine. It's pretty stinky stuff.
Excellent time for mouth to mouth resuscitation! :crazysmile:
On a more serious note, I've heard somewhere of a filtering machine that is supposed to eliminate and decompose the harmful gasses of the watch cleaning machine....maybe at cousins? I'll try to find the link. It didn't seem very expensive...worth a try considering it is our health.
Willfly,
30 years in the same trade (you get less for murder) until 6 years ago, still got a can of MEK - very useful heavy duty cleaner. Never used gloves as they would either dissolve or leak. Stung a bit on the paper cuts though!
  • 5 weeks later...
I have stripped down a cheap watch that belongs to my brother in law.  Normally I use Lighter Fluid (Naptha) with a final clean in Isopropyl Alcohol but looking at the lever I am a bit concerned that I do not know what "glue" is holding the jewels on the lever.  Looks a bit like shellac.
I use a simple small ultrasonic cleaner. Parts are put inside a mesh ball and the whole lot is put in a tiny jam jar before getting covered in lighter fluid (naptha) I then fill my ultrasonic cleaner with water and stand the jar in it vibrating away.  I have another jar with Isopropyl Alcohol in it to rinse off in a similar manner and the whole lot dries in seconds.  Everything is on a small scale as I am a Hobbyist not an artisan repairer so I do not buy litres of various cleaners and rinses but I get by and have some fun.
However, the lever manufacture looks a bit crap and I am getting bad feelings.  Does anyone think I should perhaps just not clean the lever and just concentrate on getting rid of the filings and general rubbish on the rest of the movement.  I am starting to lean that way.
Cheers, Vic
    • Yes I have that in my watch list a JUF if cheap enough I will have a go , if nothing else it will be good for spares
    • Less give a damn- more **BLEEP** it! …nice that it is keeping time I’ve done a couple of these (one with your assistance) and there’s a third that needs work on the tension between what drives the hands and the barrel. Did you have any issue with that? …and I saw Ranfft make a small comment in a thread re: pin pallets- a couple drops of Tillwich blu, let it run down the pins. It is good for 20 degrees of amplitude… I’m using this oil as a cheat code on my unmotivated Venus chrono…
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
