Goliath 2 - Bigger, Badder & Broke
Blacklab
Have been fiddling around with this for a while:
90mm diameter nickel plated case. Note the hole to the top of the hour hand from a screw used to substitute a broken dial foot. Inside is a 59mm (26'''?) Landeron 8 day movement:
The movement was patented by Amedee Douard in 1893 (see here:http://worldwide.espacenet.com/publicationDetails/originalDocument?CC=CH&NR=7032&KC=&FT=E). It winds & runs well, but the pivot on the 2nd wheel attached to the cannon pinion (does the same job not sure if it's the correct term for this) has sheared so no power to the hands:
and here's the culprit out of the watch, the sheared pivot is the 2nd item from the left:
Have searched high & low for a replacement to no avail, and I would suspect that making a new part would be cost prohibitive. Any suggestions?
do you have any idea why the arbor break ?
did  the mainspring break ?
Mainspring AOK, the pivot has a burr to one side & I would suspect this caused it to seize at some point, also it has has some rough repairs and handling in the past.
As Geo & Oldhippy suggest it needs re-pivoting. The old one will most likely push out with standard staking tools or drill out the broken end which but ever fix is decided a new pivot will have to be made. Sorry just no easy fix without a lathe or a remplacement part
Thanks for the input all. It will just have to wait for a part or the eventual lathe. Have seen some on fleabay obviously owned by this bloke:
Failing that, Cousins do a nice cheap Bergeon one, a snip at only £22,995.00 (ex VAT & del).
Ok I have been looking at this for a a while but my budget does not stretch this far but believe me this is an absolute steal on the Bay
Item No.
182016351060
If on a budget on the Bay, collets will also need to be purchased.
Item No.
161835590745
Thanks for the heads up CB, but as funds are well bellow the 2 ha'penny threshold this ones gonna be on the back burner for a while. While browsing the 2 fleabay items mentioned I noticed this one: 301866507393, thieving (insert expletive) - check out the postage!
WHAT !!! while talking about post be aware if you purchase anything of bulk from the USA the import duty to the UK is very high.
Depends what it is, how much etc. Useful calculator here:http://www.dutycalculator.com/new-import-duty-and-tax-calculation/ limited number of goes -unless you subscribe. Why doesn't the beloved HMRC do one of these?
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
