The What Was The Problem Thread.
jdm
This can be funny and challenging. Present a problem without immediate evident cause, of which the cause has been found and fixed, give some elements, and let other guess. The cause must be a very definite fact please, not just "it was dirty inside" :)
I'll begin with what happened to me today. Seiko movement is disassembled for servicing. It is put back together the bare minimum to have it run, at first it runs but because of poor amplitude and large positional variance the balance cock is removed to examine and manipulate the hairsping, this two or three times but all of a sudden it starts making snow on timegrapher which doesn't reveal amplitude (sorry no pic). Removing the balance again doesn't reveal anything visually.
Anybody?
Edited by jdm
Was the end of the hairspring slack in the stud or collar?
You got it right! I had an hint when, in despair I poked the stud arm a little and it started behaving, just to go crazy again after few moments. I was puzzled. Then with the balance removed again I found the hairspring was moving freely in the end stud. Pressed it and it's good so far.
Edited by jdm
I'll give it a shot.  But since I am such an amateur watch repair hobbyist, this case might be a no-brainer for many of you who are already experts.
Early last year, I received a non-working 1969 Omega Constellation featuring the venerable Omega 751 movement.
After replacing many parts, I was able to restore the watch.
The problem was, the watch will run for several hours and keep good time but once it stops, with the second hand between the 35 to 40 second mark, it will stop intermittently after that.  The second hand will stop at the same spot everytime - around the 35 to 40 second mark.
Shaking the watch, moving the stem, adjusting the time will restart the watch.
There was no problem with the way the hands were installed.
At first, i thought it was due to a fiber (we have a yorkie running freely inside the house) on the escape wheel, but, even after striping and cleaning the movement, the watch will still stop the same way].
When it runs, the second hand moves smoothly.  When the second hand stops, everything in the watch stops.
Here's a picture of the movement *before* I found out (or rather, I fixed by trial-and-error) the problem.  Note that the auto-wind mechanism was removed in this picture.
I knew it was too easy for you guys.   :bow:
In my case, I first suspected the slightly bent sweep second hand pinion.  But I figured it could not have caused it to stop at the same spot.
I also suspected a tooth of one of the gears in the train was damaged but after inspection, everything was in order.
I ignored the friction spring thinking that as long as it presses on the second hand pinion, it won't matter that it was not centered.  As it turned out, its edge/corner blocked a particular pinion leaf from turning.
Adjustment of the friction spring to proper shape solved the problem - and my hair pulling.   :thumbsu:
Looks like the détente has broken off the set bridge/cover plate for the keyless works.
Wow, didn't take long at all, I'll have to find a harder one next time ;-)
Part on order, just have to wait for it to travel from the other side of the planet.
Agree. It should have a little arm that has broken off. In some movements with this fault when you go to wind it changes into setting the hands because the piece that prevents this happening has broken it can also jam the winding and won't wind.
If the keyless-works were in place, they might have been dirty. Or the intermediate minute wheel had a problem.
Maybe dirt or other things might have got in between it and the mainplate. Or maybe it was bent and touching the mainplate creating excessive friction.
Edited by matabog
    • That would be something! Which brings me back to;
    • you think you're going to sleep tonight you're not, you're going to ponder the question of what makes you think those of the right parts?
    • Does anyone knows what size case a need for a dial diameter 20.60mm?
    • Sounds like the story with my Rolex. Poor (expensive) job done by an official Rolex dealer with an "in-house" watchmaker, hence I learned watchrepair and did the servicing myself. Same story as I learned with the Omega 861, again poor job by an "in-house" watchmaker by an official Omega dealer. Once your watch goes through that back-door, you have no idea what is going to happening to it 🫣   Quite nice that they sent back the parts which had been replaced !
    • yes that's definitely not right at all. I have a picture one of my friends has a Omega coaxial there was having issues to lose asking me where he should send it. As that's a specialty watch I suggested the service center. When he got it back he sent me a picture so the replace the dial as you can see the hands the mainspring barrel and I think the price was really quite decent considering all the stuff they can replace. So I do know they do change the barrels but the other person I worked at the service center when I would ask questions and unfortunately I can't remember all the answers. I think a lot of the changing a parts is at the discretion of the watchmaker. Plus I don't know enough about the chronographs and whether that would be considered a vintage watch? I take some of the vintage watches may have been sent directly to Switzerland or another service center. Obviously with a watch like the one down below they probably have a infinite supply of parts is its relatively modern vintage stuff becomes more interesting even the watch companies don't have necessarily infinite supply of parts. But no matter what the watch shouldn't disintegrated six months that's definitely an issue.
