The What Was The Problem Thread.
jdm
This can be funny and challenging. Present a problem without immediate evident cause, of which the cause has been found and fixed, give some elements, and let other guess. The cause must be a very definite fact please, not just "it was dirty inside" :)
I'll begin with what happened to me today. Seiko movement is disassembled for servicing. It is put back together the bare minimum to have it run, at first it runs but because of poor amplitude and large positional variance the balance cock is removed to examine and manipulate the hairsping, this two or three times but all of a sudden it starts making snow on timegrapher which doesn't reveal amplitude (sorry no pic). Removing the balance again doesn't reveal anything visually.
Anybody?
Edited by jdm
Was the end of the hairspring slack in the stud or collar?
You got it right! I had an hint when, in despair I poked the stud arm a little and it started behaving, just to go crazy again after few moments. I was puzzled. Then with the balance removed again I found the hairspring was moving freely in the end stud. Pressed it and it's good so far.
Edited by jdm
I'll give it a shot.  But since I am such an amateur watch repair hobbyist, this case might be a no-brainer for many of you who are already experts.
Early last year, I received a non-working 1969 Omega Constellation featuring the venerable Omega 751 movement.
After replacing many parts, I was able to restore the watch.
The problem was, the watch will run for several hours and keep good time but once it stops, with the second hand between the 35 to 40 second mark, it will stop intermittently after that.  The second hand will stop at the same spot everytime - around the 35 to 40 second mark.
Shaking the watch, moving the stem, adjusting the time will restart the watch.
There was no problem with the way the hands were installed.
At first, i thought it was due to a fiber (we have a yorkie running freely inside the house) on the escape wheel, but, even after striping and cleaning the movement, the watch will still stop the same way].
When it runs, the second hand moves smoothly.  When the second hand stops, everything in the watch stops.
Here's a picture of the movement *before* I found out (or rather, I fixed by trial-and-error) the problem.  Note that the auto-wind mechanism was removed in this picture.
I knew it was too easy for you guys.   :bow:
In my case, I first suspected the slightly bent sweep second hand pinion.  But I figured it could not have caused it to stop at the same spot.
I also suspected a tooth of one of the gears in the train was damaged but after inspection, everything was in order.
I ignored the friction spring thinking that as long as it presses on the second hand pinion, it won't matter that it was not centered.  As it turned out, its edge/corner blocked a particular pinion leaf from turning.
Adjustment of the friction spring to proper shape solved the problem - and my hair pulling.   :thumbsu:
Looks like the détente has broken off the set bridge/cover plate for the keyless works.
Wow, didn't take long at all, I'll have to find a harder one next time ;-)
Part on order, just have to wait for it to travel from the other side of the planet.
Agree. It should have a little arm that has broken off. In some movements with this fault when you go to wind it changes into setting the hands because the piece that prevents this happening has broken it can also jam the winding and won't wind.
If the keyless-works were in place, they might have been dirty. Or the intermediate minute wheel had a problem.
Maybe dirt or other things might have got in between it and the mainplate. Or maybe it was bent and touching the mainplate creating excessive friction.
Edited by matabog
    • I have that French tech sheet too, it is a little different than the English one (eg, it doesn't have the auto works diagram). BTW, it looks like you are looking up the case number in the 1979 ABC supplement. The 1974 ABC catalog does have the 3093 case. As you determined it takes the 1222-5 crystal.  When I serviced my President 'A' (which also takes that crystal), I was able to fit a 29.8 crystal from my DPA crystal assortment. Those are, in my opinion, a great deal. The assortment comes with 10 sizes each from 27.8mm to 32.4mm in 0.2 increments. I pretty much use them for any non-armored crystal that takes a high dome crystal. I think they no longer make them but Cousins has still has some in stock but when I bought them they were around $40 for the set and now they are around $100. Still, at 40 cents a crystal it's still a good deal. For the large driving wheel, I remember I once assembled the keyless/motion works first and when I placed the large driving wheel it was interfering with the setting wheel on the dial side as the teeth were not fully meshing and it wouldn't fully seat. If that isn't the issue I got nothing and am looking forward to see how you solve it 🙂
    • Not sure, but just looking at it, it seems like the screw on the right may be a fake? The one on the left may not be a screw in the regular sense at all, rather a 2 position device, I think you need to point the slot towards either of the 2 dots and one will secure and one will open. Like I said this is just my best guess looking at the pictures.
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
    • Welcome to the group Stirky. You can search for just about every subject in the craft here. Don't be afraid to ask if you can't find the answer that may have already been covered ( some ad nauseum LOL ). You don't have to buy Bergeon to get good quality. There are many decent mid-range tools available that will last you a lifetime. Cousins would be a good place to start . Cheers from across the pond ! Randy
    • I picked up a similar amount of these jewels some years ago in a watch and clock fair. Every now and then they come in handy. This week I've got a rubbed in bombe jewel in the balance cock that is cracked and needs replacing. Very handy to have a vintage assortment of these type of jewels!
