Hi all
What are the options when it comes to Mainspring Winders for the larger barrels found in Pocket watches, I have sets from Watch-Craft and a K&D set but neather came close to the size of the Barrel on the watch i was working on today, i did manage to get the spring in using the largest adaptor in the Watch- craft set but it was quite a bit smaller than the barrel, where there any sets available that were made for larger sized barrels.
Thanks for any help with this.
Paul
What size was the barrel as Bergeon do up to 19mm but they aren't cheap.
In the past I've made some of my own using stainless tube and a suitable arbor from my set.
Edit
If I was making one again and had to buy the tube I'd go for brass.
You'd need 3 tubes of reducing diameters and a couple of plastic disc for the pusher part as sketch below.
Edited by AndyGSi
The Barrel measures 21.75mm and the biggest Watch-Craft winder is 16.40mm
The Watch is of a Swiss made watch so maybe Bergeon would be the only option, I know they did a Clock set that started at 21mm and that one just looked like a bigger version of their current winders.
Edited by Paul80
Spelling
I suppose it comes down to how often you'd use it if you can justify around £100 for the Bergeon compared to probably £30 max to make multiple ones.
