10 hours ago, mbwatch said:
Yeah - it's a 42 degree lift angle, measured visually. And remarkably it runs with the same amplitude, a weak 175 for >30 hours. Just chugs along and keeps time in 2 positions. I'll figure that one out another time.
One of the problems with watches made before timing machines and vintage watches would be do they really have to have 300+ degrees of amplitude?
On 4/27/2025 at 10:09 PM, nevenbekriev said:
This Potence tool is so ingenious, but actually, the traditional way to do the things is much more simple.
Well I would think that depends on many factors. This was the same Potence clip my father made when he attended the Bulova School after WWII, so maybe it's just that different places teach differently
I had to go back and verify what were talking about because I wasn't sure with the terminology what exactly you are discussing. Then yes depending upon where you are on the planet and when you are there is all sorts of differences. When I was in school the instructor George showed me how to make one.  Such a simple device to make and so incredibly useful for 18 size full plate watches I wouldn't think of putting one together without it.
Update on this project. Where it was left last week, I was not quite getting an unlock on the entry stone and had to start adjusting it inward.
Following Nev's advice to push it all the way back and then gradually move it out until it had correct action with the escape wheel, I moved it not enough on the first two attempts. First time it didn't lock at all, second time it just barely caught the escape tooth and the watch ran with about 10° of amplitude and the balance merely wiggling back & forth.
I attempted to move it again and the front edge of the entry stone fragmented away. It was possibly fractured during the many reassembly rounds. Darn. Well I have a couple of additional Elgin 18s watches made in the same decade that take the same fork and stones (x546 old style) so I swapped in a different fork with good stones. It didn't lock at all, both stones needing to come out. I removed shellac and starting with the exit stone which was worse than entry, and it also fractured as soon as I grasped it with tweezers to pull it out.
So clearly my technique at pulling pallet stones out is poor. I now have 1 fork with a good entry stone and bad exit stone, and another fork with a bad entry stone and good exit stone. Next step is obvious to combine them and hope not to damage another impulse face.
Otto Frei is so far the only source I have found for Elgin pallet stones, but at $30 that is as much as I paid for both my inoperable 18s movements. elginwatchparts.com does not list separate numbers (nor do ofrei) for entry and exit stones on the older Elgin 18s. Does this mean they are the same stone pointing different directions?
On the bright side, I let the watch run with the broken entry stone and it actually did tick at about 100° of amplitude and no lubrication. So I had at least gotten close with positioning the entry stone before I attempted to swap the forks.
Is there no room to feed a driver into the rear of the slot ? Twist it to push out the stone.
Not that I realized, because I have not done this before. Maybe there's a small bevel at the back edge of the slot that would fit a 0.6mm driver when the stone is pushed all the way back. I didn't think of this. The slot does grip the stone very tightly, it is difficult to get any motion from it except when holding tweezers parallel to the slot and pivoting the stone vertically.
One thing that makes these Elgin forks difficult is that they do not lay flat on a bench block with the arbor seated in a hole. They have 2 "layers" so I'll have to find something to support the crossbar if I pushed with a driver blade.
Need more practice...
The other thing that makes pallet forks like this interesting is or some of these interesting it when they're not level they don't fit well on the pallet fork warming tool and melting to shellac becomes a challenge.
One of things you want to do when working on vintage pocket watches is accumulate broken pocket watches and swiped the jewels from them. Because as you're finding out the vintage jewels were probably not made out of Sapphire there are made out a Garnet and Garnet doesn't seem to hold up as well as shellac. Then the last little part about stones pointing in different directions doesn't make sense? There's always a left stone a right stone angles are different and they both have to be in the same direction. Although I once had a pocket watch command were somebody put one of the stones in backwards and surprisingly the watch ran.
Then on some watches I done this with 12 size watches I've been able to swipe pallet stones from other 12 size not even the same company because they may have purchased or stones although Elgin I know at some point in time did make their own tools and had a separate section of the factory that made diamond grinding compound for all their lap and during work. Then when the company got liquidated the diamond division was sold the somebody else in the last I knew it was still running out there but not of course under the Elgin name. Still making diamond grinding compound.
From the 1915 parts catalog you can see all 18 and 16 size pallet stones are basically identical. The difference is what they're made out of and one of them that they didn't policy side in stone probably in a seven jewel watch no one would ever see that anyway. Then you have a new or the old style determines its thickness and you would have of course right and left
Then I'm attaching a PDF of Elgin escapement terminology is it is nice drawing to show you the difference between the left and right stones.
Elgin watch company Escapement Terminology.PDF
See I wondered about this because Frei only lists one part for 18 size, no left or right options whereas they specify left and right for the other sizes. (I happen to be working on a grade 88)
I recall seeing an old video of Elgin making laps and jewels in the factory (maybe you were the one who shared it)
I have one very weird warming tool which has springy jaws that can open wide enough to hold this type of fork flat, and it swivels so you can position either side over the heat source.
It works great for melting shellac on a firmly held fork EXCEPT can you guess what its fatal design flaw is?....
....you cannot open the springy clamp once it has been heated because you would need to pinch them both between your fingers and you get a second degree burn. Genius.
For those interested in this video, it is here
Mark
I can't get over the fact this was a feature length film about jewel production, and it is fascinating.
Failure! I attempted to pull the bad exit stone from one fork (came out without further damage) and then pull the still good exit stone from the other fork but it crumbled like sand. I had soaked it in alcohol about a half hour and all the surface shellac brushed away.
Oh well. This one will go back in the box until I have another compatible fork; probably not going to spend $30 on a jewel. It was a bare movement from a junk box and nobody will miss it.
1 hour ago, mbwatch said:
pull
Seldom do I have to remove pallet stones. But maybe an experiment with the bad stone rather than pulling it out what happens if you? I'm trying to figure out how to word this. Often times if pressure is put either on the top or the bottom of the stone typically at the end the stone will become angled of course either up or down. So rather than pulling the stone out what happens if you push on it were at angles itself to its almost this is really worded very peculiar but I'm proposing instead of pulling you pushed down on it and get it to rotate and then you should build I have basically less side contact on the stone that makes any sense at all. It is actually quite easy on full plates for instance when you're putting them together to overlap the escape wheel to in the pallet fork and end up with the stone at some weird angle and it's as easy to do that it might be easier to get the stone out that way than by trying the political out where yes they seem to be quite tight even without the shellac
I do understand what you are describing, and it is how I got into this situation in the first place - insufficient shellac and assembled the full plate in a way that hung up a pallet stone on the escape teeth, knocking it out of plane and then I re-shellacked it too far out, wouldn't unlock, and this entire thread.
I think with the one I broke most recently, I was trying to get it to pivot in the slot by lifting it upward rather than directly pulling. I said "pull" but just meant "remove". This is because the prior two I broke felt like they crushed inside my tweezers. And this one shattered while I was trying to get it to pivot.
All this surprised me because I have reset the stones on Elgin 6 size movements also from the 1890's without any drama. They were fairly easy to slide around in their slots, but these 18 size have been trouble.
Edited by mbwatch
Sorry I have this thread forgotten.
Now, why the stones break? Several reasons: One - the old stones are crunchy. Be careful! Two - wrong tweezers. Use brass ones. Three - wrong approach. The best way is not to grasp the stone close to working side. Grasp it for the middle part, the tweezers direction to be perpendicular to the stone. Use oscillating tilting movements when moving the stone.
Now several tips that are not read from the books, but found in my practice. They are good for my way of correcting pallet stones position:
You don't need the heater for adjusting the stones position. The heater will be needed only to glue/fix the stone when the adjustment is already done.
The stone should seat tight enough in the slot without gluing. Tight enough so the movement will work normally and thus checking if the adjustment is correct is to be done before gluing. If the stone is loose in the slot, then heating and melting the shellac will make the stone move in by the capillary force. So, if the stone is loose in the slot, then find out if the stone is not correct or the slot is opened. If the slot is opened, then (in steel pallet forks) it is good idea to anneal locally only the small part that forms the slot before trying to close the slot. Also, put in the slot something slightly thinner than the pallet to limit the amount of bending
If the stone must go out, the shellac can stay in place, it will not make the adjustment harder. Just bend the stone to break the bond between the shellac and stone. Then heating only will glue the stone again if the shellac is not old and degraded. If the stone must go in, then the shellac mus be removed from the slot bottom as to make space for the stone to go in.
I often use pallet stones from USSR Slava alarm clock for pocket watches repair. Slava pallet stones are usually bigger (wider) than needed) and I grind/lap them to correct size for the slot. Grinding is of the side that never contacts the EW teeth. It is enough to put the stone on the lapping plate, pres on it with finger and move it forward/reverse several times while pressing, then check in the slot.
  • Thanks 2
Thank you very much for your tips @nevenbekriev.
When I broke these, I was grasping them with steel tweezers parallel to the fork slot, grasping them on the top and bottom of the stone. I do want to learn this procedure for to be successful on old watches, and I will practice when I have more spares and supplies.
On 4/27/2025 at 11:08 PM, Mercurial said:
There is a tool that was made for setting up and adjusting escapements of full plate watches.
There were two styles, the picture below shows both of them.
@Mercurial is this also a variation of the tool you posted?
    • Thanks for that Andy, Yes the new bracelet is worth more than the watch itself, Its one I have bought to service and clean-up and on-sell it as a project, look it may sell to someone who has a small wrist, I think I will buy an extender and may-be offer it up with a normal strap as well CJ
    • Not always that simple. Typically the only reason we would have any way of identifying a watch is if parts were available at any time and somebody had a parts reference book then they would help you to identify the watches that they have parts or. Unfortunately there are hundreds of thousands of watch movements with no identification and of course typically no parts the classic place were watches would be identified would be under the balance wheel and your pictures don't really show a good view of that. Occasionally I've seen watches marked under one of the plates. They felt very proud of their watch is a very prominent Swiss company and they ask he stamped the bottom of a plate so you have disassembled find it. Then there is the other system the keyless parts make up something called the fingerprint system but you still haven't given us enough information to make use of that. Here's an image showing what a fingerprint system looks like. The PDF is based on the physical book the physical book has sizes of watches these are smaller ladies watches and keyless parts which in the physical book are printed at the actual size of the watch parts. So to identify with the keyless we need in your case diameter measured on the dial side and a good picture of the keyless parts and then you have to hope that this was made within the right time span of the books that have this system on the other hand a lot of times on the dial side they will also put markings. So basically to identify a movement it has to come out of the case and has to be disassembled.
    • The strap is a 44Q6JB and hadn't realised how much they'd gone up in price. The used one I've got is very worn but may have other links floating around.
    • @Mercurial is this also a variation of the tool you posted?
    • Thanks Andy, The bracelet is sized very small, around a 14cm wrist. Were would one try to source original links, I guess they wouldn't be cheap if found. The bracelet end links have 4406 B-E stamped on them, is this the Seiko Bracelet code ?? CJ
