Watch Repair Talk Website Design
Mark
I decided to change the design of the site. The main reason was that I was tired of the huge banner at the top which was always there.
I hope you guys don't mind, however, if you prefer the old design you can change back as long as you are logged in. You will see a link at the bottom of the page "Change Theme" and I have made "Old Theme" available there.
:thumbsu:
  • 10 months later...
While this topic is active, I might as well put in a suggestion: the .crosshatch CSS style of the current theme adds a lot to the rendering time and makes Safari on my Mac stutter when scrolling pages. If I remove the crosshatch (via the web inspector) scrolling speed becomes normal again.
{    /* background: url('/Images/crosshatch.png'); */
    background-repeat: repeat;
    background-attachment: fixed;
Hi everybody.
Mark, I have a problem and I don't know if it is common to others, related with this migration, or not for all. Even I logoff my seccion, when I came again to the WRT site, I was logged on. It's happened for me for the last several logoffs.
It is normal?
Thanks
Clear your cookies, I have a website & migrated to the same software as here & some members where reporting having issues with being logged off between visits or having trouble logging on in the first place. once they cleared the sites cookie & got a fresh one everything was OK.
Hi again. I made this but still the same . :pulling-hair-out:  I really don't know what I must do to fix this (assuming that this problem is in my PC). Yesterday night I left the site with "Sign Out", but today morning I'm back already "Signed In". I don't have problem with this but if it is a problem of the site, I suppose it will better to investigate what is wrong. Any other suggestion?
I remember to did no check any box, and only was show the box asking me if I want to remember my password. I never do this for all softwares or sites. Now, I can't see any box to check as when I open the site I am already login.
Cheers too
Ricardo
Edited by RicardoG
The box is checked by default so you will need to click on the box to remove the check mark. Since it doesn't show now, I will assume you will need to clear the saved passwords, cookies, history, etc in the tools menu if using explorer. Then re open the page and log in, taking care of removing the default check mark and accepting cookies afterwards since the page requires it.
Hope it helps,
Bob
I again. I did try to do all again. Clear all my cookies and clear all my temporary internen files and historic (now every site that I go with password to login, ask me to remember or not...), I saw the checked box you told and uncheck again, and even all of this, still the same. I am not worry due I am only one that use my PC, and I bring this to here only because I thought could be a problem of the site or of the server. I can live with this and save me time to make logon . :D Anyway, my sincere thanks for the help. I appreciate.
Ricardo
Edited by RicardoG
    • The problem sounds very much like what might happen when failing to do the reset procedure. The stopwatch not working could be a few things.  There are two different motors, one for the center sweep seconds and one of the minute counter.  Damaging a coil is the most likely thing to do wrong when changing the battery, but that would likely just take out one of the two.  So "start" it wait and see if the minute counter doesn't tick over.  If that ticks, and you've done the reset procedure, it's probably damage to the sweep second coil. If neither works, then it could be the button contact is damaged.  It's a tiny bit of copper trace on the PCB that curls around the edge to make a circuit and it can break off.  There's a way to trigger the buttons from the small pads on the back of the movement, as well as check them with a multimeter, if you are familiar with one. But give this a try, pull the crown out to the second position and hold down button "B" (10 o'clock) for a few seconds.  This is suppose to spin the minute counter to let you reset it to 0.  If it doesn't move and (I assume) button 'A' (2 o'clock) doesn't start the chronograph, then either both buttons have failed at the same time or there is something else wrong. A leaking battery can take out the traces on the circuit board, and this can take out the motors and/or buttons, but you didn't say anything about it and it should be obvious if it leaked enough to do that.
    • Perhaps not where you live, but here in DK, you get by the taxman financially quartered if you order from outside the EUSR. These center wheel weren't that expensive 5 - 7 years ago, around $45-$50. I guess stock is drying up and these days we have to pay with worthless confetti money.
    • A little cleaned up, don't think I will polish the brass. Nice caramel color I think. Looks like the inscription says: Ludwig & Fries Frankfurt A.M.  The lanterns were a little tweeked but able to gently flatten out with no breaks. The 6 and 7 pivot beds are broken but the rest of the beds are intact. Box and velvet a bit rough but still functional. Overall nice and just a bit larger than the one above. Why I need 2 I haven't figured out yet...
    • Good job! Wear it well.. .
