Screwdrivers Choices
  • 2 months later...
You can use Bergeon tips. The berilium tips are not for tightening certain screws and are designed not to scratch the watch. One way is to use one screwdriver with steel tips to loosen the screw and continue with the berilium one...Horotec also make excellent steel blades and also specially ground tips... just as Bergeon.
In the US, ofrei, probably borel and esslinger offer a variety of them. In UK I'd try cousinsUK.
I never understood those soft screw driver blades, from my perspective, they're more likely to cause damage, imagine trying to undo a screw somewhere on a movement then the screw driver deforms, slips out of the screw slot and slides into the hairspring.
A decent steel screw driver blade + control is all I've ever needed. The geometry of the blade is designed not to scratch, so scratching screws should be a very rare occurrence, better to have a screw driver that will hold its form.
But to answer your question, I can't think why other brands of blades shouldn't fit the horotec screw drivers, they use the same size increments? .60 .80 1.00? unless the blades are wider or smaller at the screwdriver slot for some reason. (not accounting for the flat section that's filled away for the grub screw to tighten down on.)
Edited by Ishima
Indeed a softer metal is meant to avoid scratches, then certainly if it's soft as butter that's too much.
Bergeon sells two types of premium tips,  packaged individually, the standard 4917 and the softer 8899 which cost twice as much. Both are 100% anti-magnetic.
Probably the idea is that one had both and use accordingly to the need.
All the other types and brands come 10 per pack and cost much less. I've not tried any of these.
I finally bought the Horotec Set of 10 stainless t-Type Screwdrivers (MSA-01.207). I used the larger drivers and was very pleased.
Today I had to use the .6mm and the .8mm for an old Omega Ladies watch (455 mvt). The lever set screw snapped the .8 and the second of two case screws (retaining screws) that needed the .6mm broke the .6.
These screwdrivers fit the screws well and I know how to apply the right amount of pressure while keeping the driver square to the screw face. I've used the Bergeons for over thirty years and switched since these were always soft (with intent) and bent with difficult screws. I was hoping that with the better fit of the hollow ground (T type) drivers I would have more consistent results. Again, the fit was good...better than my bergeons but that tip is too brittle. They snapped on screws that my bergeon had no problems managing.
Has anyone else had problems with this set? Are they all tempered to such a high hardness or is it possible I got a bad batch of heat treated drivers.
Thanks for any comments.
This is the second time I hear about Horotec failing. The first time was one of their press models. I wonder if they are, lately, outsourcing their stuff. I use Bergeon too, btw. You can also use Bergeon tips on those screwdrivers I believe.
That's not good at all given the price. The curse of Horror Tech strikes again.
The ironic thing is I posted an article about cheap Chinese screwdrivers a couple of years ago and then read a few posts at different times where folk have said that they would be a waste of money. I can tell you they have been very well used over the last couple of years and have never broken or twisted. I have dressed them twice over that period, but I would expect to do that with any screwdrivers that are being well used. I can honestly say they are the best value tools I have ever purchased, and I have way too many tools!
Here's my original article. http://www.watchrepairtalk.com/topic/260-great-deal-on-screwdrivers/?hl=screwdrivers
Yeah, at this point, no matter what you pay you can never be sure where the stuff is coming from or what quality you are going to get! Stating the obvious, quality is always an issue therefore people are willing to pay a little more for a brand that has a track record of good, dependable equipment. It seems times are changing and it is not the case anymore. Alternatively, and back to the main issue, tips on screwdrivers can be shaped in any fashion necessary for the job so when a certain brand/quality tip is tested good, it can be modified to better serve...a pain sometimes but given the state of things...Oh well!
  • 4 weeks later...
  • 5 months later...
Horotec do some nice screwdrivers? But prefer Bergeon as i have used them before?
I was a little disappointed when i ordered a new set of 5970 the other day?
Have a set of this before. And wanted an other similar set for Swiss screws and movements.
The other old  i am saving for Seiko and Citizen watches.
The new one  where both shorter and had a larger diameter then the old ones? Heavier also? But great quality nevertheless.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
