Screwdrivers Choices
But you are all missing the point. The final mark of quality is that the blades should be dressed with the Horotec or Bergeon twin roller sharpener that produces parallel faces at the blade end. $$$$$
It does make a lovely job Colin, but not required unless you just have to have hollow ground blades.
As others have said, it's the quality of the blades that's the most important factor.
However, I decided to treat myself to a recent birthday present with a set of VOH screwdrivers, they are an absolute pleasure to use (and have a nicer feel than any Bergeon, Horotec or AF that I've used).
post-1141-0-93290200-1446762517_thumb.jp
But I also use various other screwdrivers where one of the VOHs isn't suitable, these are mostly tailored and dressed for individual tasks, here are about half of them  :biggrin:
And also as others have said, shaping and finishing the blades is critical to maintaining good tools and reducing the risk of damage to scres and other delicate bits.
post-1141-0-25424600-1446762709_thumb.jp
Edited by JimInOz
I suppose this is a "sentimental" 2.5 mm screwdriver issue, otherwise I would get a different brand, readily available from your preferred -- read expensive -- brands, whichever one you choose. The nice thing about screwdrivers is that there are tips available separately so maybe, just maybe a VOH for say, 2.0mm tips, with a little elbow grease may "host" a 2.5mm tip...of course the color code will be screwed up...pardon the pun.  :)
In any case, I hope you find what you are looking for.
Cheers,
Bob
They are as good as Bergeon and the tips fit each other. Some people are partial to them rather than Bergeon. Also they offer different models just like most everybody else. Honestly, I made my set a little bit of everyone so I could compare and am using mostly the cheaper Bergeon one (about $100 set of 9). All that said, it is mostly out of habit rather than because of niceties. The rubber covered ones are probably better to my taste but somehow they still get second choice. Go figure! In the end it just a matter of habit and individual preferences...at that level of quality.
Hope it helps your decision,
Cheers,
Bob
I'd hold out for a VOH and only get a cheapy if you really need a 250.
I think it would make you grit your teeth every time you saw the **BLEEP** child among your VOH beauties.
I know it would me.
Best of luck with your hunt.
Cheers
Jim
post-1141-0-21308000-1447717269_thumb.jp
    • Here is the insert ring for rectangular or elliptical movements: Note that the length is the side with the stem cut out on the spreadsheet (in the picture below this is 15.15: Here is the fake pdf file, again you need to convert to .zip after download to access the FreeCAD and 3mf files. Rectangular insert disc.pdf
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
