Cut The Stem
danizzz
Hi guys need your help again!
I have to change the stem on a screw down kind of watch (submariner type).
Now I have the new stem that it's longer than the original and I have to cut it.
How to do it in a very precisely manner on this kind of watch?
Do you use glue to screw the crow on the stem or just screw it?
Which kind of glue is the best for this operation?
Ty
Check this from Mark our forum owner.
Could be a little trickier to find the right length with a screwed down crown .
I did one the other day and is the same as regular crown one.
1. Measure how much of the stem the crown takes in.
2. Fit stem and mark it at the pendant tube edge.
3 Add length from .1. and cut there.
I meant to post this a while ago.
FOR SCREW DOWN CROWNS.
A) Screw down the crown tightly onto the case without the stem and measure the distance between the bottom of the crown and the case.
B ) Screw the new stem tightly into the crown, then insert into the watch until it engages and locks into the movement.
C) Press the crown down firmly as far as it will go and hold it there.
D) Using the vernier callipers, measure the distance between the bottom of the crown and the case.
E) Subtract the size determined in (D) from the size measured in (A) then subtract a further 0.15mm from this size. This is the amount to shorten the stem by. This should allow the crown to screw full home without compressing the stem too tightly between the movement and the inside of the crown.
F) Cut the stem leaving it slightly longer than the size determined in (E), and dress down to size using the diamond lap and vernier callipers as described in the original post.
G) Screw the crown onto the shortened stem and check fit and function, before using a tiny spot of Loctite to secure.
  • 3 years later...
I am confused but I think, perhaps this may not be correct.
First, to keep all length as positive numbers, the size measured in (A) needs to be subtracted from size determined in (D), not vice versa.
The stem also needs to end up being shorter so it will not bottom when the crown is screwed down. That additional space of 0.15mm has to be ADDED to the result of  (D) - (A), thus increasing the amount to shorten the stem by.
So, the formula should be: Length-to-be-cut = (D) - (A) + 0.15mm
1 hour ago, vinn3 said:
  basic math if you remember.  the stem cutting and thread shaping requires some thought.   i do not glue crown to stem,  just set it "tight".   vin
After having more than one crown come off and get lost, and the one on my dad's Rolex that comes off in my hand when I set hands backwards, I use a drop of lock-tite. I am able to get the crown off when I need to, but it doesn't come off from the backwards setting. But if tightening works, all the better. My dad's watch was serviced by a pro, so I was surprised that it came off so easily. FWIW. Cheers.
1 hour ago, Nucejoe said:
Is this type " submariner" a front loader?  If the back is removable, fitting is easier the one piece stems.
3 1/2 yrs old posting, we never heard from the OP anymore.
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
