Cut The Stem
danizzz
Hi guys need your help again!
I have to change the stem on a screw down kind of watch (submariner type).
Now I have the new stem that it's longer than the original and I have to cut it.
How to do it in a very precisely manner on this kind of watch?
Do you use glue to screw the crow on the stem or just screw it?
Which kind of glue is the best for this operation?
Ty
Check this from Mark our forum owner.
Could be a little trickier to find the right length with a screwed down crown .
I did one the other day and is the same as regular crown one.
1. Measure how much of the stem the crown takes in.
2. Fit stem and mark it at the pendant tube edge.
3 Add length from .1. and cut there.
I meant to post this a while ago.
FOR SCREW DOWN CROWNS.
A) Screw down the crown tightly onto the case without the stem and measure the distance between the bottom of the crown and the case.
B ) Screw the new stem tightly into the crown, then insert into the watch until it engages and locks into the movement.
C) Press the crown down firmly as far as it will go and hold it there.
D) Using the vernier callipers, measure the distance between the bottom of the crown and the case.
E) Subtract the size determined in (D) from the size measured in (A) then subtract a further 0.15mm from this size. This is the amount to shorten the stem by. This should allow the crown to screw full home without compressing the stem too tightly between the movement and the inside of the crown.
F) Cut the stem leaving it slightly longer than the size determined in (E), and dress down to size using the diamond lap and vernier callipers as described in the original post.
G) Screw the crown onto the shortened stem and check fit and function, before using a tiny spot of Loctite to secure.
  • 3 years later...
I am confused but I think, perhaps this may not be correct.
First, to keep all length as positive numbers, the size measured in (A) needs to be subtracted from size determined in (D), not vice versa.
The stem also needs to end up being shorter so it will not bottom when the crown is screwed down. That additional space of 0.15mm has to be ADDED to the result of  (D) - (A), thus increasing the amount to shorten the stem by.
So, the formula should be: Length-to-be-cut = (D) - (A) + 0.15mm
1 hour ago, vinn3 said:
  basic math if you remember.  the stem cutting and thread shaping requires some thought.   i do not glue crown to stem,  just set it "tight".   vin
After having more than one crown come off and get lost, and the one on my dad's Rolex that comes off in my hand when I set hands backwards, I use a drop of lock-tite. I am able to get the crown off when I need to, but it doesn't come off from the backwards setting. But if tightening works, all the better. My dad's watch was serviced by a pro, so I was surprised that it came off so easily. FWIW. Cheers.
1 hour ago, Nucejoe said:
Is this type " submariner" a front loader?  If the back is removable, fitting is easier the one piece stems.
3 1/2 yrs old posting, we never heard from the OP anymore.
    • as you took the mainspring out what did it look like? It's amazing how much amplitude you can get if the mainspring actually has the proper shape. last week I was doing a 12 size Hamilton and was very much surprised with the beautiful back curvature the mainspring had. Then the watch had a really nice amplitude the group would be so proud it was 350 until I dropped the lift angle down to 38 that drop the amplitude quite a bit below 300. then with the beautiful back curve it still had really nice amplitude the next day. I really wish all my mainspring's look like this as the watch had beautiful amplitude the next day. So many of the aftermarket pocketwatch Springs I see now do not have anything resembling a back curve may be a slight curve and that's about all. They still work but they just don't work as nice as a properly made spring. then Omega as all sorts of nifty technical documentation unfortunately every single corner is watermarked with where it came from who downloaded it etc. very paranoid company. On the other hand I will snip out images like from the document on recycling a mainspring barrel. for instance here's the section on what your mainspring should look like. water damaged a lot of times means rust was there rust on this watch?
    • I dont understand why a patreon membership would have limited places ??
    • Welcome to the forum, enjoy. It’s highly unlikely you will be able to purchase a new bezel look on eBay for a pulsar watch for repair to find a bezel.
    • just one little minor reminder here this isn't your normal balance wheel.  pages 17 and 18 are what you really want to be looking at. normally studs don't turn but this watch has the etachron system designed for lots of adjustment. Personally I would try to rotate the stud back to where it's supposed to be. If you're lucky you didn't actually bend it at the stud it just looks really bad as the stud has been rotated grossly out of position.. I think things will look a lot better if you put the hairspring back where it's supposed to be by rotating the stud. it's hard to tell if you actually did bend it at the stud or not we won't know until you rotate the stud back more or less where it's supposed to be. Then you want to pay attention to the manual of how to put the hairspring back in the regulator pins because yes they rotate also and they rotated specific directions otherwise bad things will happen to your hairspring. so initially you can open up the regulator as wide as it can go and don't worry about closing it until thing everything is right then you can close them a little bit
