Have A Laugh Tools
jdm
On ‎10‎/‎2‎/‎2019 at 3:00 PM, yankeedog said:
When it  comes to buying cheap tools,I am like a dog chasing a skunk..I never  learn.
     when it comes to "horse play"  in the machine shop;  I am a veteran !  think "oxy acetelene"   and spark plugs.  vin
  • 1 year later...
I had a credit with a shop form when I bought some braking grease for some binoculars that I was restoring. Somehow I ended up with 2 on the order. When I paid for it I realised the mistake.. They would not refund me the money for the second tube, just gave me a store credit. Just got a Pin Vise from them today. Made in India, not China. Go figure. Anyway, the revolving end, much like those cheap 'precision' screwdrivers that you can buy, is actually on a bearing. The knurling on it is really good. The collets, there are two double ended ones, are quite good as well. I am really quite surprised to tell the truth.
Reminds me of a recent visit from our local plumber. I had attempted to unblock the bath drain with caustic soda, which was a complete failure. As a result I now had a solid lump of caustic soda, old hair and calcium in the U-bend.
The plumber, who I know quite well arrived with a plumbers grade fix for the problem in the form of sulphuric acid.
We poured in a tiny amount and there was an interesting explosion. Rather than do the obvious and desist from continuing this potentially disastrous line of repair, we agreed the best course of action would be to remove the entire blocked U bend and continue the experiment outside in the adjacent barn.
Safely away from more sensible adults, in said barn,  more acid was added, and a fountain of interesting highly caustic brown goop ejected itself violently from the poor unfortunate plumbing piece. Naturally we tried again with similar results and much amusement from two individuals who should know better. In the end we just replaced the U bend, as for some strange reason it had cracked.   Do not try this at home children.
Edited by AndyHull
  • Haha 4
Post a picture? India has a good tradition in tool making. For watchmaking their Anchor brand is the South Asia equivalent of Bergeon, distributing a wide range of tools. I have various and all are worth their low price, just some adjustment is necessary sometime. Often they come with beautiful wooden boxes making the purchase worth for that only. Cousins UK carries a wide range, your pin vises could be from them.
If you get serious about machining (not necessarily a good idea) check out out Soba tools and Zither chucks. Chronos.ltd.uk and arceurotrade.co.uk carry these, I have some, want more, and nothing to complain about.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
