Have A Laugh Tools
jdm
  • 4 weeks later...
Here's another one. Chinese hand setting knock-off set, not even that cheap.
They did not match any color marked on the box, there is no flat head, and two or three were of the same size. Fortunately that was easy to fix by re-drilling to measure and labeling.
post-1542-0-37541500-1448915588_thumb.jp
Edited by jdm
I'm getting good at finding these. Pin vice from the shop that claims to be your uncle's sons.
  • Double Ended: Ø0 to Ø1.20mm & Ø1.50mm to Ø2.50mm
Which is not really true, the actual pin sizes with which you're left on your own are 1.50 - 1.70mm.
Inexactness in deficiency :)
  • 7 months later...
I bought this pin remover tool on Aliexpress for $2.35. The idea of a screwed base to adjust to the pin height is good, problem is that at some point it hits. Also, the threaded shaft is lose and wobbles, total width is way exaggerated, and the spare pins are all 0.8mm which can or can't be the right size.
Still I can't complain as the same thing on Amazon is 9 euros or so.
All in all, the plastic $0.64 ones from the same seller are probably better :)
When you guys are sad or bored, please have a look at Aliexpress.
From a sapphire crystal listing (which In Chinese English are called "sapphirine chips"
Please leave a message of which size you want, or it will be sent randomly
  • 2 years later...
Resurrecting an old thread. Elsewhere I've posted about my bench polisher, which is perfectly executed with insulated wiring, spare motor brushes, and precise concentricity. What I find laughable is  the 12/17mm stamped wrench, supposedly for the chuck arbor - which has a 14mm cut. Better nothing at all!
Good topic...
I think mine has to be the first tool I ever bought for the hobby, the ever present on ebay cheap Indian screwdriver set.
Here is me trying to be a serious watch repair person with my loupe in place and my new screwdriver poised above the movement...then the tip falls out into the movement...the horror, the horror...well after I got over the initial shock I started laughing so hard the wife came in to see what was so funny in the world of watch repair.
I am a mechanic by trade and know the value of quality tools. Why I ever bought them is still a mystery to me.
The cheap brass set screw would not stay tight for love nor money and finally stripped out all together. No matter what one did, every time I picked one up the tip would fall out.
I also deal with a lot of Chinese assembly instructions. The good ones are kept in a folder for when I'm feeling down and need a pick me up.:D
Bought these two Chinese G-clamp sets at the chain store, but on different days. Same shelf, same label, same price - not even that cheap. Mediocre quality, but that I can accept. What is surprising is that at one factory, 3" is about 75mm, but at the other only a bit more than 60mm :huh:
Edited by jdm
  • 3 months later...
2 hours ago, jdm said:
Clamp from the above after 2 months straightening a cabinet door. Looks like is made of recycled rust and dross.
I think you will find the Chinese instruction manual specifically says, not suitable for use on cabinets.
不适合在任何地方使用
A machinist mentor told me it was a standard prank in the shop to ask to borrow the new guy's micrometer, then clamp up parts with a dummy mic (some old junk mic), holler to the guy that his "clamp" was hard to tighten- from across the room- then when he freaks toss it to him in a way he can never catch it.
All that said I've seen some c-clamps that were so sorry they should have paid people to take them, and others that could probably serve as decent micrometers. I'm not anti China-cheap stuff, sometimes you find gems for practically free. But usually you get what you pay for.
More surprisingly usable than having a laugh but.....
EBay 'why not, if it's really bad it's so cheap it doesn't matter' order, 99p incl delivery, (quickly enough to be UK based as the seller claimed though these often aren't which doesn't matter to me when buying cheap things). Battery for the led included and even decent sturdy box with it.
20x loupe on spectacle frame with led.
For very brief close inspection of teeth, jewels, pivots etc certainly good enough I previously used a 14x for this and my 5x on a wire loop for general work but the convenience of slipping the 5x up and the spectacle design on is worth it.
You have to wonder how they can do it.
Edited by m1ks
Funny, but - you cannot pay incredibly low prices and expect professionally executed  tools. Not fair IMHO.
Some of the cheap tools can be improved easily with little effort to get a still cheap but usable tool.
E.g. change the brass screws against steel ones for few cents in the above mentioned Indian screwdrivers. You can even use swiss blades. BTW loose screws and dropping blades will annoy you with swiss/french screwdrivers, too!
For years now I use a cheap Indian sliding pin tong for holding certain barrel arbors. Initially a ridiculous tool, after machining the suitable opening it serves its purpose perfectly.
Frank
   i have one of these.  it is metal ,  not plastic AND ; it's still not worth  a shite !  vin
   that wrench has a " special use".   i have had to grind a good wrench down to that size !  (some air grinders, for X)
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
