Swatch Eta 2840 Walkthrough
Swatch ETA 2840 Walkthrough
Based on a summary research, this movement is very similar to the ETA 2801 et al family. Nevertheless, Ranfft doesn't list it as part of that family and instead says it is made only for swatch watches. All in all, the movement comes encased in a laser sealed case made of either plastic or metal. They are supposed to be throw away/disposable watches not meant to be serviced. The plastic crystal is supposed to be buffed when scratched, not replaced, since, again, it is laser welded to the plastic case.
The irony models usually have a pressure sealed backs, being reinforced with a metal ring at this area, and can be opened. Due to the nature of those cases, movements can be found in almost pristine condition once the case is opened. That is, they mostly fail at the lug area where it attaches to the band (plastic breaks).
At times, the case ruptures and then the above does not apply. Also, there exist a belief that in order to fix something in these watches we need to break something to get at it. Example, break the crystal and cut the stem, to get to the movement. Again, it is not necessary in some models.
@My friend Colin: If you are reading this, it is with great pleasure I will be using the cases you so kindly gave me. I know it has been a while but for a busy hobbyist like me, things take time...but they get done...eventually! Always a pleasure to say hi!
So without much ado here is the disassembly of a Swatch ETA 2840:
Swatch ETA 2840 Walkthrough.pdf
To be continued.....
Due to time constraints, I had to do a pdf for faster download. Hope it works well.
Cheers,
Bob
Edited by bobm12
Pdf update
Enjoyed that.  Whats going on with that Intermediate wheel?  Is this coated with some kind off life long graphite paste?
Where did you get that Kif tool?  I recently purchased one from eBay, but not as pretty as yours :)
Is that your tool fetish kicking in again Micky? :D I think the tool will be the same as yours, it's just that Bob has his held in a pin vice.
Cheers,
Bob
 Message received. Thanks,
Colin.
Yup, guilty as charged.  Here's the one I purchased from a US eBay seller..
Edited by SSTEEL
@Colin: Most welcome, Colin!
@Micky: Absolutely Micky, those are the cousins and/or ofrei offerings....probably ofrei in my case and yes, as Geo said, held in a pin vise. The little springs are a pain, once they ping away it is bye, bye...or maybe buy, buy! :)
Also, what you noticed on the intermediate wheel is rust! I was able to clean it up a bit but chances are it has to be replaced. I'll work on it a little bit more today, time permitting. I can't explain it other than thinking about chemical interaction between the lubricant and the metal since everything else is ok...no more serious rust. Even if the case is compromised, it is not very likely that whatever rusted the wheel only affected it and not the rest of the watch. Any ideas and/or solution to this mystery is welcome though! :)
By the way, I haven't tried the tea method of de-rusting. What kind of tea is the best and how do we use it? I wonder if anyone out there has been particularly successful with this method and can outline the proper/fastest way to it.
I have used the bergeon stuff and the vapo-rust. The former is like Chlorine or Alum but milder (sometimes it works and sometimes it won't, at extremes and is good to stain everything black), the second one eats the kiff springs and erodes other parts depending! So here I am again, finding a solution for a good and mild de-rusting agent! I had a bad rusted Swatch movement (one of the lot) that was so rusted I immersed it, completely, in vapo-rust but I lost all the kiffs. The parts that were badly rusted didn't really de-rust and some other stuff came out separate, i.e. staffs and wheels came apart, etc. I would not recommend it to anyone.
In any case, it is fun so far!
Cheers,
Bob
Hi guys,
Thanks Geo, excellent picture, just like my tool!
@rogart: The dials are great, rogart, thanks for the pictures. I believe one of my movements has a date ring, must be an ETA 2847 or something...still in the watch though.
@jaycey: Here goes my star explanation, hopefully I'm making some sense! There is a plastic ring (it is sectioned, narrowly, at one end to allow for the stem to have free passage) that surrounds the movement. It is rather thick and fits the cavity in the case in one position, then it is turned 1/4 clockwise or so to secure it. To free the movement the opposite has to be done, then, by grabbing each end of the cut section we do as if to straighten the ring effectively releasing the movement...did I confused you still more? :) I can't take a picture now but I'll post one as soon as I have an opportunity.
Cheers,
Bob
Hi guys,
Cheers,
Bob
Thanks Bob,
You have confused me slightly because I asked how the dial attaches to the movement, but you have given a excellent explanation of how the movement is secured!
I ask because I don't see any fixing points for dial feet?
I am guessing though, by your explanation, that the dial and movement is secured using some sort of locking ring method that you explained above. Correct?
No jaycey, and sorry for the misunderstanding, the dial seats on the ring I described and is pretty much lose but partly supported by the case also. At least that's the way so far with those broken watches I'm practicing on. In fact, the dials are not exactly a full solid circle but more like a ring. You can see most of the movement from the front as if they were -- but they aren't -- skeletonized. So, the dial is only minimal or a designer's type.
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
    • Could you glue two pieces together for rigidity and separate after forming?
