I slowly get together all the parts I need and I also decided to built my own amplifier.
Since etching my own circuit board seemed like to much of a challenge for me I decided to go with an assembly kit I found at a local electronic dealer for a mono microphone pre amp which offers a 1500 fold amplification.
There are different options on how to assemble the kit depending on whether it is used with a dynamic or a  capacitor microphone. From what I understand, the way a piezo element works resembles more the way a capacitor microphone works and so I'm going to solder the kit accordingly.
What do you guys think?
I'm not sure, you will have to test it and let us know how it turns out :lol:
Is it easy to disassemble the kit if you want to try soldering it the other way?
I'm currently waiting for some parts for a different type of pre-amp that I ordered from China, but it is taking abnormally long to arrive...maybe the package got lost.
It would be nice if you had a schematic diagram? The capacitive microphone requires a biased voltage. The piezo microphone and dynamic microphone do not.
Here is the link to the operations manual as a pdf. It's only available in German but it contains all schematics.
It says that if you use a capacitive microphone you need to solder resistor R6 onto the circuit board an the electrolytic capacitor C1 needs to be in reverse voltage direction.
I also studied the manual in the meantime. To that specific issue it says that you need to make that modification if you want to use a microphone without separate power supply like e.g. a capacitor microphone.
What kind of pre amp did you order.
Since I only soldered together some audio cables and have absolutely no clue at all about the principles of electrical engineering it is very likely the I will need one of them as well :lol:. Really hope your package didn't get lost though!
2 hours ago, JohnR725 said:
So as you discovered R6 is not needed for a piezo pickup.
wait, i personally came to a different conclusion. My train of thought was  that i would need R6 and C1 reverse since the piezo like a capacitor microphone does not have a separate power source an therefore I would need to pick up the power from the amp.
Unlike a capacitor microphone, a piezo doesn't need a power source. And a dynamic microphone is a power source.
This circuit option seems very efficient. Especially that the voltage can be from 3 volts to 25 volts.
Mono Preamp.pdf
Mono Preamp.pdf
The gain of that circuit is only about 100 (40dB), which probably won't be adequate, and despite what the manual says, it won't run off of 3V. At 3V, the input signal is biased at 1.5V, which is of course only 1.5V below the chip's supply voltage, a point above which it will not operate. Put another way, there is zero headroom if operated at 3V. The only thing it will amplify without severe distortion is total silence.
Edited by svorkoetter
Thanks for the clarification. The circuit has not physically tested it. And I had the suspicion that it did not work on the edge of 3 volts. But the explanation is appreciated. I only have one question left and I appreciate the help: would it work with 5 volts from a USB port?
Guido,
beware, the input resistance of that circuit (1 k) is too low for a piezo disc!
With a bit electronic knowledge much can be adapted at this standard design. E.g. plug in a more modern OP replacing that grandfather of IC and it will work at 2V and lower.
Frank
So far, the kit that Eland posted seems to be a good option for someone who doesn't want to start from scratch. I will pick one up when I'm in Germany later this month, and give it a try. The thing I like about it is that it doesn't use a proprietary part. The LF351 is generic, has multiple sources, and has been around for a long time. I just haven't had any experience with it before now.
Dear Sirs. I share with you a record recording of a Omega Lemania Caliber 9160A. 18000 bph stopwatch. According to my records it presents approximately 4.8 seconds of advance. The beat error is approx 0.2ms and the amplitude is 270 degrees or so. The elevation angle is adjusted by 41 degrees. I share it because someone can be useful. I also want to inform you that to pick it up I am using a caiman clamp to which I soldered a 27mm piezo electric disk with a modified PYLE PP444 preamplifier. In addition to improve the sound and filter unwanted noise I am using the applications for windows: PEACE + APO EQ I also leave a screenshot of the configuration. There are 30 seconds of recording that can be played as a loop.
https://mega.nz/#!HaQFTSxA!FATJQ6XI8FYjQBBGqtPjvdVj1i6bZp7RwI5uBgaL7ng
Hi, Frank. Thanks for the data you share. I wish to clarify that I made a mistake in indicating the breadth in my publication.
He had indicated an amplitude of 270 degrees. But it is not correct. What you publish is correct. Approximately 235 degrees. Excellent application It strikes me that in addition to indicating the value of beat error in milliseconds, the program also indicates it in degrees. According to my assessment that is very useful, because to correct it, it is necessary to pre-visualize approximately how much the collet must be turned on the balance wheel staff or how much movable stud must be moved.
Thank you
Hi,
in my workshop I service mainly vintage chronographs. To adjust the beat error, I always have to rotate the collet. To see the pallet position and in which direction to rotate,  I use to let down the mainspring, look, wind again.
This means, after every check there is a different state of winding and amplitude.
Beat error will show different [ms] values for the same error angle then, but beat error [deg] always shows the same value for the same error. That is why I like [deg] display for the beat error.
Frank
I wanted to post a quick update on my timegrapher. All together I encountered a lot more difficulties then i thought. I screwed up the amplifier assembly kit  by using blunt wire cutter and thereby accidentally ripping the conducting layer of the board as i tried to clip the wire of a resistance.
I also have the hardest time soldering the brass pin onto the piezo element. I broke several piezos by applying to much heat an bringing the ceramic layer to crack .
I'll visit a good friend of mine in January who is a electrical engineer and we'll try to get it done together (using his professional equipment).
Until then I wanted to ask @24h if you have any special techniques u used to establish the connection between the pin and the piezo and also if you could elaborate why you used a rubber casting around the pin. I thought it might rather weaken the vibrations and therefore the signal.
at least I am making a little progress with my timegrapher stand. Here is a picture of my first built (which is not functional because there is no piezo on the end of the pin):
  • Similar Content
    • Like losing Ranfft. That was a wake up call. We took his website for granted. Miss him terribly.
    • Its 4 o'clock in the morning here in the Uk, i cant sleep, i dont sleep, not much ever really. My brain never shuts off to rest, I'm just a constant thinker, i have to be very tired to be able to sleep,  i guess eventually it will be my undoing and my health will suffer because of it I'm sure. But while I'm here i want to get as much out of life as i can, and give as much as i can, to help,maybe to make a difference to someone's life if that is within my capability,recent events have made that need even more clear to me. I'm not sure where I'm going with this or why i bring it up , or if its relevant to want i want to talk about its just in my head right now. What i do want to talk about is something thats been on my mind for ages. I like to be prepared,  I'm not fond of surprises because surprises take control away and i am a bit of a control freak at times. This forum, Our Forum if i can call it that, is here because of two reasons. The guy that created it and keeps it funded and the people that joined it.  Without either, it would not exist, and lets face it one day it won't ( I'm a realist and i talk about things others dont or who are afraid to in other words folk that dont particularly prepare for the inevitable). How many of us visit here regularly ?  How many among us almost depend on the forum as a way of socialising because they are stuck at home and how many of us has it become part of a daily routine to check in and see if they can offer advice or get help with something they are working on or just to have a chat and engage in some banter. The members here are in the thousands and thousands have disappeared over the years many had just a fleeting visit. But there are a good few of us that know each other quite well and visit regularly. I dont know about you but i wouldnt want to lose that communication with you all, in all honesty it has become an important part of that side of my life and helps to feed my passion for all things watches. Some of you may think differently and thats ok, some of may stop and think # what would i do " Without Our Forum " #
    • Naptha appears to be a general name and its content can be varied depending upon what it's specific use is. Lighter fluid as an example can be light or heavier also with other ingredients to help it burn. Try sesrching for benzine ( as opposed to benzene which is linked to causing health issues ) . There are other fluids such as ethanol that you could try and also methylated sprirts, mostly ethanol with a small percentage of methanol added. Experiment with any new chemical to see how quickly schellac dissolves in its presence. I have tried a few things but hexane is not one of them, i understand it does evaporate very quickly.  Be sure sure to check out any safety data on chemicals you try. Toxicity of fumes and flash point information, ultrasonic machines can heat up fluids even without a heater function. And of course always ask here for personal opinions when trying a new substance.
    • I have that set and really like it. I prefer that crystal holder over the one that came with my Bergeon claw tool and any time I use the claw I use this one instead of the Bergeon one, just an additional bonus with this tool.
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
