D. I. Y. Watch Timing Machine.
Which is closest to the ones you have? -
I agree with you completely for older watches, but the Revue 30 dates from 1910 onwards. They were still being made up until at least WW2, and there is reasonable parts interchangeability in my experience, assuming same jewel count. Very early Revue 30 movements will be less tolerant of replacement parts being fitted without adjustment than the later ones. Escapement parts were the last to require hand fitting to eachother in each watch and are thus unique to the movement but the other parts from even an early Revue 30 should be interchangeable within watches with the same jewel count. Since the escape wheel is part of the escapement there is no guarantee, but it’s likely an escape wheel from another 7 jewel Revue 30 will fit this watch. The escapement will need adjustment (pallet stones, safety action etc) may need adjustment to set up the escapement optimally, though. Best Regards, Mark
By HouseofGeorge · Posted
Thanks for the tip. I'll have another look just to be safe. But, shouldn't there be like a splined or geared end to unscrew the tube? This one is just straight tubing. So, I tried contacting Cousins UK asking if these pushers come with the tube or not and unfortunately they couldn't help and their website has no documentation if it does come with tubing. That said, do they come in complete, ie tube, gasket, pushers? I'm not sure which of these two would be more appropriate: Thank you. -
By LittleWatchShop · Posted
Well, when you first posted some time back, I downloaded and ran it through my slicer to get a print time. A bit long for me. Your new idea would solve this. I am anxious to see your progress!! -
Just arrived, i thknk i know what most of it is for, though there are a few obscure items , some watchmaker made by the looks. I love the arbor vices, and not quite a complete screw polisher among the lot. The six in the last picture I'm not sure about but i have an idea about 1 or two of them.
