5 minutes ago, praezis said:
In fact you have. I wonder if you already blew your ICs?
You should connect:
+9V to V+ pins
0V to V- pins
4.5V (TLE2426) to +In pins.
Frank
Here is the original schematic that I followed.  Apparently he had it working in this configuration.  What am i missing/doing wrong.  Do I just have the V+ and V- pins swapped?  Sorry, as I stated I am new to this stuff...  Please be easy on me...LOL!
You should connect:
+9V to V+ pins
0V to V- pins
...and think about my 2nd question.
Frank
He has not built this schematic yet...he needs the gain because he is probably taking it off a piezo to listen to a watch.  Depending on how it is physically built...it may just be 10s of microvolts.  So, you need a lot of gain.
You are correct about the power pins...lol...I should have caught--I had seen the original schematic and was concentrating on his mod.
V+ connects to to pin 7 of the 5534.  V- connects to pin 4 of the 5534.
Same for LT1115.
Ground (your artificial ground) connects to pin 3 of of both opamps of the 5534.  The LT opamp is in unity gain.  The bias resistor connected to pin 3 connects to ground.
Edited by LittleWatchShop
fixed error
Same for LT1115.
Are the bypass caps connected properly?  Should they be connected to the artificial ground or v1?
I will ? .
Did not see that you just rebuild the design. So my question goes to the designer.
According my experience and many measurements, a piezo pickup produces 50...100 µV from the most quiet watches, upto 10 mV and more from pocket and loud wrist watches. Then compare it to the level that a mic input can handle (usually << 100 mV).
Frank
3 minutes ago, praezis said:
I will ? .
Frank
Does the circuit look correct now? image.thumb.png.e52a232bfc704862374e422ec4ee1a92.png
I don't doubt your numbers, but I think it all depends on how he builds the sensor (microphone).  If it is clipping, he can reduce the gain in the last amplifier (and adjusting caps accordingly).
You drew this in Tina?  Does Tina generate a spice netlist?  You should generate a netlist and then simulate your circuit in LTSpice.  This will both confirm your design and let you see the peak gain and bandpass characteristic.
Better yet, I would have drawn it in LTSpice so that everything is all in one place.  You are not linking your schematic to your layout, so the schematic tool really does not matter from that perspective.
I am attaching an LTSpice file I generated when I first started reading this thread.  It uses generic opamps, but the library has the LT opamp.  You will have to punt for the other two components, or go find a model on the web.
Watch amplifier_b.asc
Here is the netlist exported from TINA
UPDATEDOPAMP.CIR
Here is a sim from TINA, I will draw the whole thing over in LTSpice later and post everything so everyone can enjoy my pain...
sim.tdr
23 minutes ago, xyzzy said:
If this is connected to an ADC, and one can apply any filter they wanted digitally after that, is there a need for the analog filter stages?
You are correct...in general.  In this case, I don't think @cwrnh has control of the software.
If one were to, say, implement a timer with an Arduino, pre-filtering would make the task easier.
Here is the simulation of your netlist
So here is an updated TINA schematic with some values changed and two resistors added.  And The new PCB layout to match.  Also attached the netlist.  I am working on the Ltspice schematic now.  I have LtSpice and have used it but like TINA better. (Probably because I am new to all this).  I will import the components and spice models and post the new drawing when finished.image.thumb.png.ca65d82f3c3c167308cf59d12858f5da.png
UPDATEDOPAMP2.CIR
8 minutes ago, CWRNH said:
Okay, thanks I will try that.
I can't figure out what I am doing wrong in LTSpice to simulate the net list.  I guess I have to import the Spice models first.  I keep getting errors.  Have to learn and relearn so much stuff...LOL!
This is one of the things that makes this discussion interesting. Everybody has different ideas. It also depends upon what you're connecting it up to as to how much digital filtering capabilities you have. So maybe just an initial filter knocking off everything under 1000 cycles is all you really need. Or maybe just a couple of transistors with no filtering at all.
Hello all, finished reading all posts last night and the first thing I want to say is a thank you, thanks for Stefan and all of the others who contributed. I read the posts with great joy and these posts are the reason why I like this site so much.
The reason why I ended up with this topic is that after about two years, I felt the need to dive a little bit deeper into a watch anatomy, and for that, I needed a stethoscope or using a different name of it: a watch timing machine. A while ago i bought a Weishi Timegrapher NO.1000, but i have not used it much. I tried it once and that's all really. I thought i repair/service a few low cost watches and if it is successful i put them back to eBay, but i figured that probably it would be a good idea to check their performance before i sell them. First of all that would be the fair thing to do, then i would get my money back I spend on them with a tiny bit of profit, while I learn for free. Now some of these old low cost watches would not need a timgrapher because some of them are so bad that the Weishi for example would not even be able to listen to them. However I am climbing up on the ladder and I recently serviced or resurrected a ronda 1217-21 movement in a Services 17 jewels watch, one in such a bad shape that I thought it would be impossible to make it work again before. That movement gives us a nice readable sound and it is full of opportunities for learning including listening to its heartbeat. Earlier i saw a debate what is needed first a microscope or a timing machine, i am not going to give you an answer for that debate, but i am going to tell you that I had both and at the beginning I found the microscope incredibly useful while I did not use the timing machine at all. As a beginner the only thing what mattered for me that the watch was ticking at the end after the cleaning / servicing and re-assembling/lubricating process. At the beginning I ruined them permanently more often than not so there was no need to check the performance of a dead watch.
Now, I also bought two microphones a while back because I tend to buy things where i see a unique opportunity even though i dont need the subjects in question at the time of buying them. I took a few pictures of one of them where i need to replace the sensor:
IMG_20210217_143220.thumb.jpg.f82d90544df2d7c57b8b32c21bfaf6ef.jpgIMG_20210217_143157.thumb.jpg.0e9d5bc44e411be7a1687ec9b448e4b7.jpgIMG_20210217_143323.thumb.jpg.8862bc7398d3efd895c84fb6b4b40c07.jpgIMG_20210217_143337.thumb.jpg.0618b22af60b71bb384a1996cca3818f.jpgIMG_20210215_115616.thumb.jpg.a13b1fcc4061d74e287457bb2115666e.jpgIMG_20210215_115625.thumb.jpg.0b033feba6dcc6b6b8316fe2d564e68e.jpgIMG_20210217_115421.thumb.jpg.9d9b0aa67da67c85d3429e8e04f583ff.jpg
As you can see the sensor is in a really bad shape and need to be replaced, it seems like most of its stuff just evaporated. I assume that John answered this question as why earlier, but I am not sure so I am going to ask a number of questions following this post. My original plan was to use this microphone with open source TG and after that idea I found this topic. First thing first I need to bring this microphone back into life.
You must admit that this microphone has a cool factor. ?
And look at this:
science watch-timers
science watch-timer 2
Edited by luiazazrambo
correcting English - hopefully
On 4/21/2020 at 3:07 AM, JohnR725 said:
Then because the originals are water-soluble I'm reasonably sure that they're made of Rochelle salt (sodium potassium tartrate tetrahydrate) It's amazing what you can find on Wikipedia.  So what will happen with time is They will absorb moisture and just disintegrate.
@JohnR725 Is this the reason why my sensor looks like that above?
  • Similar Content
    • This post has some pictures that describe how to get the spring back into the setting without having to disassemble anything.  With patience, this approach works.  The advice that the spring will ‘float’ back in when positioned just right is spot on. If you try to push it so it flexes and pops back into the setting, it’ll probably just fly away, as you’ve already found.  Hope that helps, Mark
    • I recognize myself all too well. It takes a lot of experience and discipline to recognize when it's time to cancel and come back at a later time. Very well said! We should have a forum dedicated to this topic as it is critical to achieve success when working on watches. It's a lot more important than most other things related to watch repair. And yes, just a short break can make a world of difference!
    • Hello Wai and welcome to the forum. A little information to enlighten you a little more TZIllustratedGlossary.pdf
    • I am certainly not the first one who happen to ruin the chronograph center-wheel of a Seiko 6139B. The internet, when you search for it, is littered with stories, even here on WRT there are some. One of the problems is that the service manual of the 6139A is readily available on the net, not so with the service manual of the 6139B. On top, reading other forums & stories, there are people who claim that there is hardly any difference between the 6139A and the 6139B movement, so the 6139A service manual will suffice. However, one of the crucial differences is the design of the chronograph center-wheel. Also the Seiko reference numbers are different. For the 6139A, the reference number for the chronograph center-wheel is 888610 and for the 6139B: 888611 or 888612, depending on which manual you are reading (and perhaps there is a difference between these two wheel too !??) To lubricated the 6139A chronograph center-wheel, the following graphic picture in the 6139A service manual is given; One has to press down the sprocket and oil it. Unaware of the difference in chrono center-wheel design, I pressed down on the sprocket, but there was no movement. Perhaps not understanding or interpreting the drawing correctly, I pressed with the tweezers on the 4th wheel. This caused the 4th wheel, which turned out to be a press fit to the sprocket by the 6139B, to strip off the sprocket. Thereby me joining the line of all the others, who tried this before and are now searching for "how to fix" this misfortune. In an older thread on WRT, member @ricardopalamino place a picture in which he shows the difference in center-wheel design between the 6139A and the 6139B. To the left the 6139B and to the right the 6139A. As can be seen on the left center-wheel, the 4th wheel is pressed onto a sprocket. Pressing down on it, as shown in the 6139A service manual, gives a ruinous result. People did several attempts to repair the damage, but so far, I haven't found a success story. Here is one of the attempts; Reading what already has been tried, I tried a different approach ..... but sadly failed too. Nevertheless, I'll show what I've done; perhaps somebody may fine-tune or expand on the idea and has success? In my staking set was an anvil with a 4.5mm hole, exact the size needed to fit the chrono center-wheel "up-side-down". The distance between the clutch parts and the 4th wheel was 0.25mm. To support the 4th wheel as close as possible up to its center, I used feeler gauge blades, on one side a 0.25mm blade, and on the other side a combination of 0.15mm + 0.10mm blades. This allowed me to tap the sprocket back onto the 4th wheel ...... The thickness of 0.25 blades doesn't prevent some "spring" action, and so my 4th wheel was slightly deformed. The re-attachment seemed successful, but when trying to true the wheel, the connection failed again 😭 Currently there is a NOS 6139B chronograph center-wheel on eBay. Last Sunday the price was €150, on Monday the seller increased the price to €165 !!         Prevention is better than the cure and I do hope that anyone in the future, searching for a 6139 manual, with read my "Warning". As for my Seiko, I'm not going to invest €165 for one part and since the rest is pretty good, I will sell the watch for "parts or repair" 😞
    • Off the top of my head I can't remember which was which, but one of the hands had the clutch with the very fine radial teeth as described above, the other had a flat disc with two tiny 'pins', there was what looked like the remains of something black smeared on the opposite face, maybe the remains of rotted rubber? When I can get some good pictures of both I will post
